Finding a Donor car
Posted: Thu Feb 19, 2009 8:28 pm
by JoshyC
hey!
i want to put a 2.5 engine into my 318, just wondering if it matters where it comes from, i.e can i use a touring donor even tho mines a 2 door or is the running gear different?
p.s if anyone has a 325 they want rid off let me no :D
thanks!!!!!!!!
Re: Finding a Donor car
Posted: Thu Feb 19, 2009 8:29 pm
by GrindCulture
Any car will do as the running gear is the same no matter what body style.
Posted: Thu Feb 19, 2009 8:36 pm
by JoshyC
cheers!
can i use the 318 diff or am i going to need the lot off the donor?
Posted: Thu Feb 19, 2009 8:39 pm
by GrindCulture
You could use the small case from the 318, but it might not hold up to the B25s torque for very long, plus the final drive might be a bit short for a daily.
Posted: Thu Feb 19, 2009 8:47 pm
by JoshyC
i take it i can leave the 318 brake servo in place nd the master cylinder? i mean can i keep the original clutch fluid lines and all those bits and bobs
Posted: Thu Feb 19, 2009 9:05 pm
by leeparkes
JoshyC wrote:i take it i can leave the 318 brake servo in place nd the master cylinder? i mean can i keep the original clutch fluid lines and all those bits and bobs
They are all the same,not too sure on the clutch slave though!
