1. Offside front seat belt anchorage prescribed area is excessively corroded
2. Offside track rod inner ball joint has excessive play
3. Offside front suspension has excessive play in a lower suspension ball joint.
4 Offside front (inner wing) suspension mounting component prescribed area is excessively corroded
5 Offside front (floor) suspension component mounting prescribed area is excessively corroded
6 Rear brake pipe excessively corroded
7 Nearside front brake pipe excessively corroded
8 Offside rear (boot) suspension component mounting prescribed area is excessively corroded
9 Offside rear (under floor) suspension mounting prescribed area is excessively corroded
To add insult to injury, she also failed on front brake imbalance, parking brake efficiency, excessive CO2 emmissions and a knacked washer jet and headlamp bulb but I can sort these myself.
Other than that, all is well
Question is for the welder types out there, does this sound fixable at sensible dosh or is it time to sell off some some Mtech 1 bits and a decent leather interior?
