m30 afm??????
Posted: Mon Jul 04, 2005 5:47 pm
by 325dude
allo all is it true about fitting an m30 afm to a 325 make alot of difference if so does anyone have one???????.............j
Posted: Mon Jul 04, 2005 5:52 pm
by Ant
Fozzymonster had a fully modded unit for sale a while back dude, its been fitted with the 325i PCB and spring so tweaking should be easy as.
you'll need to increase your fuel pressure to around 3.5Bar to see the gains
for those that knock the swop.......... have you actually tried it ?? BMW SA used this AFM on the 2.7 powered evo models iirc
8bhp, 11 lbs ft are the best increase over stock I've seen reported, not bad for the outlay.
Posted: Mon Jul 04, 2005 6:30 pm
by Demlotcrew
Bin it!
A
