Sump Guard
Posted: Mon Oct 27, 2008 10:18 am
by bad_ass_mk4
Unfortunately i became a victim of the high curb+low car= holy sump club this weekend
This'll be the third sump that i've had on the car since i bought it; the first needed replacing as it was leaky and had been bodge welded to reapair it and the second one i'd only had on 2 weeks before it met its maker this weekend. So im thinking that as i don't really want to higher the car, it'd be a good idea to get a sump guard of some sort.
Does anybody know where i can get one for a 4 pot? The only ones i've seen are for a 6'er on eBay
Re: Sump Guard
Posted: Mon Oct 27, 2008 10:43 am
by magpie
i got mine from len1 in southampton after 2 new sumps,,,,mine was 60mm drop,,,whats yours
i may sell mine as im only going 40mm in my IS .....
Re: Sump Guard
Posted: Mon Oct 27, 2008 10:51 am
by bad_ass_mk4
cheers magpie,
(and thanks for replying to my thread in the wanted section, although i managed to find one closer to home for alittle cheaper
Mmmm it does become abit of a ballache changing sumps, its not like its ever a planned occurence when one gets cracked though so i'd never really given thought to getting a sump guard as i dont usually go out with the intention of punching a hole in mine
Mines a 318i lowered 60mm at the front.
How much would you consider selling it for?
Re: Sump Guard
Posted: Mon Oct 27, 2008 9:33 pm
by papercutout
I found a diff guard in the scrappy, turned it round, drilled 2 holes in the section behind the front valance on the little lip that sticks backwards and bolted what was now the front (2 long arms) onto that.
I drilled a hole into one edge and ran a piece of scrap steel up the side of my engine to a spare hole in it, drilled a hole through it, and stuck a bolt through it! On the other side I wrapped a piece of wire around the rear mount of the guard and over my steering rack to another random hole (on the edge of the sump) and back again, tied it, jobs a good-un.
I also ripped the rivets out of it a few days ago by touching a kerb corner straight on. I also touched the sumpguard to floor just driving along country lanes that were bumpy! Will be re-riveting it ASAP because it may not be awesum or anything, but its dirt cheap, and easy to mount. (point was to stop wearing holes in the bottom of my sumps, as opposed to creating a SOLID guard that'd support an engine)
Re: Sump Guard
Posted: Mon Oct 27, 2008 9:53 pm
by magpie
mine sparks at nite it weighs 7kg boled to existin holes in cross member and cradleonly had to drill one side of front xmember as origional hole in front side,"PROPER JOB" mine was lowered 60mm jamex on 45mm legs,
Re: Sump Guard
Posted: Mon Oct 27, 2008 10:28 pm
by papercutout
7kg?! Wow, what is it, a 6mm piece of sheet steel? Mine sparks too, but i have an advantage over you - my cars about 80mm down ;) Cost me £5 too (need it fixed asap actually, that and the sump. And the petrol tank back in and the welding done)
Re: Sump Guard
Posted: Mon Oct 27, 2008 10:55 pm
by magpie
mine "PROPER JOB"no more sump probs here,
this shows my usage [sparkage]loads of sumps without this
