Towing with an A-frae
Posted: Tue Jul 08, 2008 8:52 pm
by KRAMSSAYB
Does anyone know if I can tow an E30 touring (without powertrain, prop or diff) on one of these A-frame contraptions?
Cheers Guys
Re: Towing with an A-frae
Posted: Tue Jul 08, 2008 8:56 pm
by march109
how old are you? can you gestimate the weight withought powertrain, prop or diff? and how far are you travelling?
Posted: Tue Jul 08, 2008 8:58 pm
by KRAMSSAYB
Hi,
I'm 21, the car weight is approx 700kg, and 100miles.
Posted: Tue Jul 08, 2008 9:00 pm
by oli325
A frame or dolly?
Posted: Tue Jul 08, 2008 9:01 pm
by KRAMSSAYB
A frame
Posted: Tue Jul 08, 2008 9:48 pm
by tomson
I have an A-frame that I have rescued many a sad turd with! Locally in the south west and I've even towed one from Dover and another from Manchester, both back to Bristol.
Never had any issue's and have been seen & overtaken by plenty of policemen....
HTH
by Ozstar
tomson wrote:I have an A-frame that I have rescued many a sad turd with! Locally in the south west and I've even towed one from Dover and another from Manchester, both back to Bristol.
HTH
Same as above.
Not 100% legit though.
Posted: Tue Jul 08, 2008 9:49 pm
by march109
KRAMSSAYB wrote:Hi,
Given that you are all A ok. over 700kg and it is downright illegal.
Posted: Tue Jul 08, 2008 10:25 pm
by Ozstar
march109 wrote:
KRAMSSAYB wrote:Hi,
I thought it was 750? Im pretty sure it is supposed to be braked and for recovery only.
I doubt you'l get an e30 down to that though. We have just
Posted: Tue Jul 08, 2008 10:55 pm
by Nelly
I thought there was issues with 'A' frames due to the rack being in front of the control arm and the frame 'snagging' it's self - where as a towing dolly does the trick as long as it has it's own braking system for weights over 750kg
I'd say be safe, bite the bullet and rent a trailer for the day.
Posted: Tue Jul 08, 2008 11:26 pm
by tomson
Nelly wrote:I thought there was issues with 'A' frames due to the rack being in front of the control arm and the frame 'snagging' it's self
I've not had that issue with mine, if its chained correctly to the wishbones there is no problem.
I wasn't aware of the weight issue though.
Posted: Wed Jul 09, 2008 12:00 am
by agent006
Nelly wrote: I'd say be safe, bite the bullet and rent a trailer for the day.
At 21 he'll have a 750kg towing limit on his license though. Hence a guesstimate on wight of 700kg gives very little room for error too.
Posted: Wed Jul 09, 2008 12:41 am
by Scruffymurphy
It's not legal, but I've done it myself. I towed a 325 touring over 100 miles using an A frame a few weeks ago. You just need to take it easy and don't brake hard, especially on a corner.
