Which exhaust system for my 6branch?
SilverShadow
Hartge Crew
Mon Jun 16, 2008 4:58 pm
Hi,
Does anyone have any pics/diagrams of the 2 piece and 3 piece exhaust systems that come on the M20s?
Im having trouble matching my 6 branch to my existing 2 peice exhuast system. Do i need a 3 piece system?
I rear box is a scorpion Le Mans and my centre section (with down pipes) is BMW.
GDBN
Mon Jun 16, 2008 5:13 pm
Most 6 branches will mate up to the centre section of a 3 piece exhaust.
G
I deserve 6 of the best ...
Cabrio
What manifold is it...and does it have downpies and if so how far back do they come...eg do they reach gearbox and then you can cut the centre section and fit together
SilverShadow
Hartge Crew
Mon Jun 16, 2008 5:28 pm
Automac wrote:What manifold is it...and does it have downpies and if so how far back do they come...eg do they reach gearbox and then you can cut the centre section and fit together
its the one in the below link:
http://www.e30zone.net/modules.php?name ... ht=#906987
My concern is that iv just dropped in my Hartge H27 engine into my 320i and would my current 320i exhuast limit the new engine?
Cabrio
Mon Jun 16, 2008 5:38 pm
If you put the downpipes right way round they will line up with the existing pipes on your OE system centre at or near the gearbox mount...then you can cut them and slide or tube them together...dont cut too short...if you do make a mess or want an easier option you can get the centre system to match your exhaust
cliffybabe
Powered by Nelly
Powered by Nelly
320 and 325 are the same i would go for a scorpion centre and rear box i love the sound mine makes and im runnning a alpina 6branch
Cabrio
Mon Jun 16, 2008 5:41 pm
Look on ebay if you get stuck...some on there
suchy
True Zone Relic
Mon Jun 16, 2008 9:50 pm
Yo Mr.CliffyBabe how much oversize from standard bore is your pina 6 branch? :D (sorry to jump in on this thread)
**BANNED**
Tue Jun 17, 2008 4:33 pm
Your 6 branch will need the centre and rear of a three piece system.I bought mine from GSF along with a fitting kit for about £175.I had to mod the front of the centre bit to fit my manifold(I used a Hottuning manifold) as I needed one bolted olive joint and one sliding joint.I then discovered that the centre/rear joint was not a straight forward sliding joint and ended up welding the rear and centre sections together...it fitted,eventualy...
Youth is wasted on the young.
Cabrio
Tue Jun 17, 2008 5:36 pm
Try modding your original pipe to save money...no need to buy if you do it right
If you do have to buy this one on ebay will be a direct fit to 3 different makes of manifold like yours
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=011
Tue Jun 17, 2008 6:04 pm
320's have smaller bore exhausts not sure on size but alot smaller than 325i systems which are 44mm OD and alpina 50mm
