1990 325i tappy engine?
Posted: Mon Apr 28, 2008 8:33 pm
by j3nks79
I have had the tappetts adjusted but it still sounds a little tappy. Is this normal?
Re: 1990 325i tappy engine?
Posted: Mon Apr 28, 2008 8:42 pm
by E30BeemerLad
they could be very worn but M20's to tick, the injectors make a ticking noise and can sound like tappets. Also, a snapped exhaust stud on the manifold can also give a ticking/tappet like sound
Posted: Mon Apr 28, 2008 8:44 pm
by bodger
is there any way of reducing the injector ticking, would brand new injectors still tick
Posted: Mon Apr 28, 2008 8:49 pm
by sam325is
new injectors wouldnt tick much. they will still tick a teeny weeny bit..it would be hard to notice. best to get them ultrasonically cleaned by a bosch servie centre. far more cost effective.
Posted: Mon Apr 28, 2008 8:50 pm
by E30BeemerLad
you can get them ultrasonically cleaned at about £20 each, find a local bosch agent, it's likely to quieten them down but may not stay good long term. New ones are probably £50+ each x6 = lube up
by Chris-W
Might just be a knackered manifold gasket.
Posted: Mon Apr 28, 2008 9:15 pm
by j3nks79
Seems to sound louder when the engines warmed up
Posted: Mon Apr 28, 2008 11:35 pm
by sam325is
£370 for new ones, £90 ish to get them ultrasonically cleaned. the ultrasonic cleaning is pretty impressive and i have heard very goo things about it
Posted: Tue Apr 29, 2008 8:15 am
by steve955i
had mine diagnosed as a blown exhaust manifold gasket. sounded just like tappets but with an irregular beat and seemed to go away when decelerating. also got quieter when everything warmed up...........
