ITB air filters
Fri Feb 22, 2008 2:39 pm
38mm is pretty small!! Considering the Vaux XE engine (similar 500cc/cyl) runs 42-48mm tbs
throttle response should be awesome!! will have a nice mid range also, and help hide any lumpy cam you might have
Fri Feb 22, 2008 2:41 pm
should work out ok actually.. 2v flow vs. 4v flow etc etc
oakey
Fri Feb 22, 2008 2:43 pm
38mm is small but more than big enough for plenty of power potential. What size is the standard TB? Anyone know how to work out the inside area of a circle? lol
oakey
Fri Feb 22, 2008 2:45 pm
Jhonno wrote:should work out ok actually.. 2v flow vs. 4v flow etc etc
Runner length and tb size has all been calculated for the hp I want and the rev limit :D
Fri Feb 22, 2008 2:49 pm
Pie*r^2
LOOOOOADS more area than the standard tb anyways
maxfield
Fri Feb 22, 2008 3:00 pm
I've got 263mm² for the area of the ITB's :?
oakey
Fri Feb 22, 2008 3:04 pm
maxfield wrote:I've got 263mm² for the area of the ITB's :?
Whats the :? for?
maxfield
Fri Feb 22, 2008 3:05 pm
Because I don't know how correct it is...
oakey
Fri Feb 22, 2008 3:11 pm
Well considering 38mm squared is 1444mm I think you might be :D
maxfield
Fri Feb 22, 2008 3:12 pm
R = Radius.
And the radius is 14mm :wink:
oakey
Fri Feb 22, 2008 3:20 pm
If I measure a square inside the tbs of 25mmX25mm I get a surface area of 625mm yes? Times that by 6 and you get 3750mm so surely your'e doing something wrong. Or my brain is completely fekked
maxfield
Fri Feb 22, 2008 3:22 pm
3750mm is 3.75m...
And to me that sounds a lot of surface area for TB's!
oakey
Im doing something badly wrong here with my calculations arent I? :mad:
oakey
Fri Feb 22, 2008 3:25 pm
You were right all along maxfield! That will teach me not to smoke in the daytime :D :D
Does the area of the tb's sound too small?
maxfield
Fri Feb 22, 2008 3:27 pm
I'm not sure what a good area for ITB's is TBH.
But seen as it's only a 2v per cyl engine I would of thought 38mm is about right.
maxfield
Fri Feb 22, 2008 3:45 pm
Oh shit done it completely wrong!
Radius is 19mm :o:
oakey
Fri Feb 22, 2008 3:48 pm
maxfield wrote:Oh shit done it completely wrong!
Radius is 19mm :o:
Lol! We must seem like proper numpties! My excuse is I havent been tought maths for 7 years! What yours? :D
Fri Feb 22, 2008 3:50 pm
How many zoner's does it take to work out the radius of Oakey's tbs?! 8O :snigger:
maxfield
Fri Feb 22, 2008 3:52 pm
I've slept since then :cry:
I only learned it a couple of years a go..
Does 68.046cm sound about right? 8O
oakey
Fri Feb 22, 2008 3:59 pm
Jhonno wrote:How many zoner's does it take to work out the radius of Oakey's tbs?! 8O :snigger:
More than 3 it appears :D
Besides its area were trying to figure out :D
agreen
Fri Feb 22, 2008 5:00 pm
i cant rember what size my itb's are 48mm i think 8O
so for more low down torque long trumpets ? correct ? ? ?
lance1a
South African/Scottish import
Fri Feb 22, 2008 5:31 pm
^^^^as a general rule, yes, but you might have to play with the lengths to get the torque where you want it.
With carbs, and filters straight onto them (no stacks) I was getting into 6500rpm as quick as hell, but no bottom end. In fact, when I took the 120mm trumpets off to fit the filters straight on, I though something had come loose, so much difference it made! Though the trumets I was using were too large in diameter (58mm vs 40mm venturi) so the airspeed was too low. Now with the smaller stacks the torque is almost right. I want to make up 90 dergree bends in alloy tubing of 40mm diameter, as I read that a 90 degree bend will cause a vortex to occur, and further increase airspeed.
BMW E28 528i X2
Merc W126 300E twin turbo
Merc cosworth 190e 2.3-16
BMW E28 525E
BMW E28 M535i
Saab 900 Classic Turbo
BMW E24 Highline Cosmos
BMW E24 Highline silver
BMW E24 Macau Msport
BMW 1972 2002
BMW E36 Alpina B3 3.2 Switchtronic
Renault
Turbo-Brown
Boost Junkie
Fri Feb 22, 2008 5:38 pm
Not sure that vortices in your inlet system are a good thing, pretty sure they won't increase air speed either.
