Anyone with an IS suggest anything?
Getting it 'chipped' has been mentioned but surely this is only done to make the most of proper engine mods like cams etc?
And what is this idea of removing the throttle body heat plate thing?
Available from power? Who are they? Have they got a website? I would be interested to have a look!Kos wrote:in this months Total BMW magazine, you'll find an feature on my old IS, all my mods are there , it was making 162 bhp and 149 ft/lb torque
other than that, an alloy flywheel from JB racing ( available from power 4 peanuts ) the fly whell will by like giving your car 20-30 bhp through the rev rannge ( it doesnt actually give you extra power )
you could spend £500 on cams and the same a again on a re map and exhaust and it will no be as good as getting one of these fly wheelstomtomiS wrote:yea right mate, i was thinking it was gonna be not too expensive, but custom flywheels etc, yikes!!Kedge wrote:And there was me thinking he meant it was cheap haha
Heats the air going in to the throttle body, engines run better colder the betterDan325iSport wrote: Does anyone know what the benefit is of removing the heater plate from the throttle body? Or what is does?
its makes it less restrictive as wellOBs wrote:Heats the air going in to the throttle body, engines run better colder the betterDan325iSport wrote: Does anyone know what the benefit is of removing the heater plate from the throttle body? Or what is does?
OBs
(Book marked for later!!)
with that diff in it with the light wight fly wheel it will perform very well, and probably give you a top speed of 135mphtomtomiS wrote:well kos i will take that very literally then and invest in one after ive bought a new headunit, besides mine also got a 3.64 diff in it which needs sorting out at some stage soon
Changing the flywheel mass makes no difference to the power output of the engine, it just changes the rotational inertia of the car's drivetrain. It's just like removing weight from the car really, 'cept removing 1kg from the flywheel makes much more difference that removing 1kg of 'normal' weight.Bob_S wrote: lighter flywheel? I though it was dual mass so that the torque was higher bigger rotational mass on the outside, momentum etc etc?
K&N in my experience all it does is suck in all that lovely hot air trapped under the bonnet?
adjusting the cam sprockets - I thought all this did was move the power band about and no real increase was to be had bar the fact that the 5degrees made it a little more responsive up the top end of the rev range?
