What order for 318is mods???
supremacy
Tue Apr 18, 2006 11:53 am
Hi guys,
Just got given a 1990 318 is and just wondering what mods if any i should go for??
Are boost valves worth it?? HAd one on my old 325 sport and i felt it made a difference, much smoother acceleration. Is it worth it on a 318 is??
Had a search through the forums on the subject of induction kits for the 318 is and some people are saying yes to one others are saying leave it standard. Is there a any reasons for this??
Whats the best suspension to put on??
Have been told that the running gear from an M3 will be the best possible set up, is this true???
Any help much appereciated.
Cheers guys
eko
Old timer
Tue Apr 18, 2006 12:04 pm
I had a carbon induction kit on my iS for about 2 days,then dumped it on Ebay :mad:
All it did was make loads of noise,cause a mega flat spot and generally made it shite to drive,took it off,fitted standard air box back on and it was back to normal!
Chip and S/S exhaust more worthwhile from what ive read,although i have neither of these on mine so cant comment!
There is a mod that can be done to the camshaft timing that ive read about that apparently works but again not done it myself so try doing a search for this on Google maybe :)
Tue Apr 18, 2006 12:18 pm
Start with suspension and brakes
Boost valves are shite
H&R cup kit with H&R anti roll bars is the best setup for it
Geeman
Tue Apr 18, 2006 12:29 pm
Chip , BBTB and exhaust... made LOADS of difference to mine!
Giles.
supremacy
Tue Apr 18, 2006 12:46 pm
Cheers for the advice guys.
One question, is there a specific order to the mods, eg do i go for the exahust first then the chip??
Or is this not relavant??
Thanks again guys :mad:
Geeman
Tue Apr 18, 2006 1:17 pm
Do it all at once... but buy them separately if you can't afford them all in one go, but fit them all together... then there'll be a more noticable increase in power! winkeye
supremacy
Tue Apr 18, 2006 1:21 pm
Cheers for advice fellas, now to raid the piggy bank winkeye
