M20B25 had slight rod knock, found a rod bearing fractured in two!
acme15
Wed Apr 29, 2026 10:40 pm
I'd had a slight ticking noise at higher RPM for a while which I thought was top end noise, or a noisy injector, or a slight manifold leak, but I addressed all of these things and the noise persisted.
It then became a distinctive rod bearing 'tap', at which point I stopped driving the car and tore into the bottom end to have a look.
It didn't knock at idle, or when driving gently, or when free revving. Only at moderate RPM with moderate to heavy throttle.
(It is difficult to hear because of the lower tones from the exhaust etc, its much clearer if you listen through a "tinny" speaker like on a phone.
The bearings all looked very acceptable for 210K miles with one very obvious exception...
This guy, cylinder #5.
I've personally never seen a bearing fail in this way before, and I am curious what might have caused it and how long this has been brewing!
Fortunately there was only light scoring to the crank, which I was able to fix with a light abrasive, and it all measures in spec. Lucky escape.
This is the before picture, it is now a perfect mirror finish again.
Just thought I would post this to document it in case it helps anyone in future.
1991 325i manual, 210,000~ miles.
Thu Apr 30, 2026 9:55 pm
Good catch! Perhaps you should now run it on Mobil 1, then it may reach 1,000,000 miles like a test car did back when they were new...
acme15
Sat May 23, 2026 1:13 am
It has MOTUL Classic 2100 15W50 "Modern" semi synthetic in it now.
I was staying with friends for a week or two, so I just got home and buttoned the car up today.
New king tri-metal rod bearings, clearances all good 0.40mm, 0.40mm, 0.43mm, 0.38mm, 0.38mm, would have preferred them more consistent but that's in spec so it will do.
New oil pump (the old one wasn't in bad shape though), and a new oil pressure relief valve spring and plunger, (again the old ones seemed fine), but while I'm in there...
First cold start 60psi at idle, settled down to 20psi when the oil had a little temperature in it.
Happy with that.
reggid
Sun May 31, 2026 8:47 am
hopefully those measurements are off by a decimal point
did you check the bearings for the intermediate shaft? those also seem to be more commonly an issue
E30 325is with M20B31
