Bonnet insulation REMOVAL - best way?
gillsl500
Thu Nov 17, 2016 8:08 pm
Hey chaps,
I've finally started my e30 restoration :-)!!
So first question is, what's the easiest way to remove the insulation under the hood, especially that sticky residue that's left behind as it's going to be painted.
the problem is more so the sticky glue that left behind. So any ideas are greatly welcomed:-)
DHFiS
Thu Nov 17, 2016 8:49 pm
I used a hot air gun on the lowest setting and a plastic scraper. Once it gets a bit warm you can push the glue into a lump then pull it off.
andysheep
Thu Nov 17, 2016 10:42 pm
Paint thinners to finish off the resdue :D
gillsl500
Thu Nov 17, 2016 10:53 pm
FairPlay ladsa˜€a‘a
andysheep
Thu Nov 17, 2016 11:46 pm
Crappy job, iv done twice now,good luck mate,but while doing it with the bonnet upside down ,dont dent it,i did on my cabby,very easy to do :cry:
Gert_8
Fri Nov 18, 2016 11:36 am
I think Barry suggest the best removal item was toyota's brake fluid to remove the gunk..
BenHar
Fri Nov 18, 2016 9:17 pm
Gert_8 wrote:I think Barry suggest the best removal item was toyota's brake fluid to remove the gunk..
Toyota brake cleaner not fluid!
Brake fluid will strip the paint.
Ben
Gert_8
Fri Nov 18, 2016 9:23 pm
Shit! Thanks Ben.
gillsl500
Fri Nov 18, 2016 11:50 pm
Thanks again guys, what about sand blasting it??
Gert_8
Sat Nov 19, 2016 7:14 am
That isn't going to help the paint, you may as well use the fluid.
Brake cleaner, as corrected above, is the best solution.
ianev
Fri Nov 25, 2016 4:15 pm
where does one acquire the bonnet insulation please?
Gert_8
Fri Nov 25, 2016 4:21 pm
Cotswolds on here..!
ianev
Fri Nov 25, 2016 4:49 pm
I thank you, Sir! :mad:
retroboyo
Sat Nov 26, 2016 11:09 am
I used a fag lighter
ianev
Mon Nov 28, 2016 12:39 pm
anyone have the part number for the insulation please? :?:
Gert_8
Mon Nov 28, 2016 12:42 pm
51488103798.
Bonnet insulation.
peterjcollins
Tue Dec 06, 2016 7:09 pm
I pulled mine off and then used petrol painting it on with a paint brush.
Obviously must be done outside due to fumes and risk.Use good quality PPE
ianev
Tue Dec 13, 2016 11:08 am
Gert_8 wrote:51488103798.
Bonnet insulation.
Thanks buddy!
