OEM size ARB for M3 v other thicker ones
DasChin
Wed May 22, 2013 5:06 pm
hi all
does anyone know the size of the normal ARB thickness for the e30 M3 non evo? front and rear?
I have been told you can use ARBs from a 325 sport or the convertible to slightly uprate the thickness as opposed to going H&R or other aftermarket.
is this true?
thanks, Nick
maxfield
Wed May 22, 2013 5:32 pm
DasChin
Fri May 24, 2013 7:34 am
thanks for that.
so M3 is 19mm front and 14.5mm rear.
does anyone know if the 21mm from the cab will fit the M3?
DC
Kos
Sun May 26, 2013 8:06 am
It will
www.pukardesigns.com
IG Pukar.Designs
