How do I get the paint code for my car?
The strut sticker is missing, most cars you can get it from the chassis number.
It's a 1989 black touring.
How do I get the paint code from chassis number?
- Brianmoooore
Paint code should also be on the VIN plate on the rear of the slam panel, immediately behind the RH headlamp.
- Brianmoooore
Yes, from the last seven digits, as B7 has already said.s1oww wrote:Can I tell it from the numbers on the bulk head, they are stamped in under the windscreen?
What's wrong with reading it off the headlamp plate?
Black E30s are usually either straight Black (Schwarz) or Diamond Black (Diamantschwarz), which is the pearlescent metallic one with lots of multi-coloured specks in it.
The codes of these are in this list:
http://www.e30zone.net/e30zonewiki/inde ... lour_Codes
Grrrmachine
- E30 Zone Wiki / Team Member
Remember that the car is 20 years old now, so the paint is likely to have faded. If you buy brand new paint based on the colour code, and then use it to paint one panel, you will see a significant colour difference between the new and old paint.
Best thing to do is take the car to a pro and get them to use a spectrum analyser on the existing paint to get the best match.
