What does this light mean??
e30BMart
Thu Feb 10, 2011 1:05 am
*this is not my car, the brake pad light doesn't come on in my car*
The circled light is what I would like someone to tell me what it is... It goes on and off all the time while driving! ...?
TouringTash
Thu Feb 10, 2011 1:21 am
Brake fluid level low or faulty sensor, my money would be very, very worn pads.
I wouldn't drive this car or allow it to be driven without checking the braking system visually with wheels off etc
318i Touring
SHAKEELE30
Boost Junkie
Thu Feb 10, 2011 1:26 am
what about the one lit next to it, what that for?
AlpineAde
Thu Feb 10, 2011 1:46 am
If you see that tell-tale illuminated the first thing to do is to check your brake fluid.
TouringTash
Thu Feb 10, 2011 2:05 am
SHAKEELE30 wrote:what about the one lit next to it, what that for?
The OP says in his original post, it's the pad level light.
E30's have two sensors one front left (nearside in UK) and rear right (offside in UK) though it won't be long for someone to correct that in some way.
318i Touring
e30BMart
Thu Feb 10, 2011 2:13 am
TouringTash wrote:Brake fluid level low or faulty sensor, my money would be very, very worn pads.
The lit light means pads... but as posted originaly: This is "NOT" my car. My brakes work fine and that light doesn't light up. I'm talking about the circled one (in red) that is brake fluid levels?
TouringTash
Thu Feb 10, 2011 2:27 am
The lit light means pads... but as posted originally: This is "NOT" my car. My brakes work fine and that light doesn't light up. I'm talking about the circled one (in red) that is brake fluid levels?
Yes, brake fluid.
I know its not your car I was attempting to convey how dangerous this could be.
318i Touring
e30BMart
Thu Feb 10, 2011 2:34 pm
Yes, brake fluid.
Ok hmmmm.. But it only turns on sometimes and then it might be off for a whole drive then on/off/on in 5 secs... what does this mean?
MrWhite
Thu Feb 10, 2011 2:40 pm
If it comes on intermittently your brake fluid level may be just at the low level limit for the sender?. Either that or the level sender is faulty or you have a loose connector. Either way, check your brake fluid reservoir.
rust never sleeps
TouringTash
Thu Feb 10, 2011 3:00 pm
MrWhite wrote:If it comes on intermittently your brake fluid level may be just at the low level limit for the sender?. Either that or the level sender is faulty or you have a loose connector. Either way, check your brake fluid reservoir.
+1
Check it asap dude.
318i Touring
e30BMart
Thu Feb 10, 2011 4:40 pm
righto! brake fluid is like checking oil level? in the engine bay somewhere?
TouringTash
Thu Feb 10, 2011 5:22 pm
I'll go grab a pic for you but its the little resivoir with a yellow screw cap, will have wires attached to it.
318i Touring
TouringTash
Thu Feb 10, 2011 5:55 pm
No its not yellow its the same colour as the reservoir Image
Not the cap with ZF on it as thats for the power steering
318i Touring
Jim320i
E30 Zone News / COTM Team
Thu Feb 10, 2011 6:00 pm
In my chromie the light light in the picture above that is on, is also faulty in mine, but it flickers when going over bumps in the road or knocks etc. :? Never had it looked at and on my list of things to do.
What does this indicate and what do I need to do other than check the brake fluid level? :?
adit
Thu Feb 10, 2011 6:12 pm
the left warning light is "handbrake on", the middle one is "brake lining/pad wear" and the right one is the "brake hydraulics (low fluid)" warning light, as mentioned.
[quote="bss325i"]
e30BMart
Thu Feb 10, 2011 8:55 pm
Thank you guys I'll go check it live! who knows maybe you just saved my life 8O
TouringTash
Wed May 16, 2012 10:29 pm
Did you solve your issue Jim. Either a loose wire or shorting to earth somewhere.
I've got to sort this on mine so will update here.
318i Touring
Jim320i
Wed May 16, 2012 10:47 pm
Nope, still the same :mad: Shes not been on the road since October now I think. Something I still need to sort. :(
TouringTash
Thu May 17, 2012 1:37 am
I'll have a play next week and get back to you on what I find out fella.
Hows life? still plugging away eh.
318i Touring
Jim320i
Thu May 17, 2012 10:20 am
Lifes the same :roll: Just retruned from a holiday so now feeling sad about being in the UK :cry: :roll:
TouringTash
Fri May 18, 2012 4:19 am
HOLIDAY?
What's one of those?
Never feel sad about being in England, look about you man, the fields, the greenery, the fact its still under Common Law Jurisdiction. winkeye
318i Touring
Morat
Fri May 18, 2012 9:00 am
and we still have the pound! instead of the Deutsch Mark.. .err Euro.
Jim320i
Fri May 18, 2012 10:32 am
I always appreciate the country, I went for a few mile walk in the back garden the other day and that was good apart from it was cold and damp and raining lightly.
Its the built up areas that smell of diesel and has 'people' in it that makes me sick :(
Pound? Whats that? Anything I have the missus takes away to 'look after' :cry:
TouringTash
Sat May 19, 2012 1:10 am
Pound? thats all the banks and the gov are going to be doing to all us.
What did cost a Pound that was a Pound (lb) when they were first issued?
Was all weights and measures before.
318i Touring
