NEED NEW O RINGS FOR MY E30 AS THEY ARE PERISHED AND INLET MANIFOLD GASKET CAN I BUY A KIT FORM AND WHERE CAN I FIND THEM
CHEERS HARRY
O RINGS
!!!!!how to get free ps3 hdtvs i phones and much more click the link!!!!!
http://consoles.freebiejeebies.co.uk/145408
What o rings you need Harry?
Inlet manifold gaskets there are 4 singles and a double for the centre two ports.
Main dealer are cheap enough.
Part number for the gaskets are
4 x 11611726010
1 x 11611726012
4 x 11611726010
1 x 11611726012
the ones on the injectors i think running really crap at the moment sounds if air leak that sound right ?
also idling under 1000 rpms
- fowler
- Boost Junkie
- Contact:
sounds more like inlet to me barrymate as if the o rings on injectors had failed there would be petrol everywhere
EX A-Tech Workshop bitch !!!
gone but not forgotten
the inlet gasket ? will change the o rings to just wondering if they done some kit form for all these cant seem to find the right onesfowler wrote:sounds more like inlet to me barrymate as if the o rings on injectors had failed there would be petrol everywhere
- fowler
- Boost Junkie
- Contact:
yes they do a kit not sure of the part number if you look on realoem.com and find the original BMw part number under fuel preperation subheading
- fowler
- Boost Junkie
- Contact:
sorry forgot say inlet gasket its a good place to start as you might find a defecive vacum pipe when stripping it all down
fowler wrote:sorry forgot say inlet gasket its a good place to start as you might find a defecive vacum pipe when stripping it all down
are you a mechanic ? where are you based ?
