15x10J's on the rear...
trimmer
Thu Dec 17, 2009 12:37 am
Whats a suitable offset and tyre profile for running this rim size? Arch work? winkeye
Thanks!
Kos
Thu Dec 17, 2009 12:40 am
arch work yes
tyre's well depends if you want to stretch or not
dont even ask the offset question as you will be head fucked.
www.pukardesigns.com
IG Pukar.Designs
trimmer
Thu Dec 17, 2009 12:48 am
Kos wrote:arch work yes
dont even ask the offset question as you will be head ******.
lol, just wondered what people are already running, as there must be a few with 10J RM/RS's out there? Pics with wheel spec would be helpful :)
Reason I ask is i'm speccing up some custom wheels so just wanted to get a feel for it. Offset wise im guessing probably et0 to -12 ish.
Kos
Thu Dec 17, 2009 12:55 am
i look at the orginal et if i'm working with RM's.
bith bbs split rims being built and changed, i always look at inner arch clearance. most rm's start at et35 when they are 6.5J. at that spec they clear the rear shocks, but if you are thinking about using a true coilover on the back the IS spring may not clear.
on 9J i built up, we stretched 215/40/15's on but thats difficult size to get hold of
IG Pukar.Designs
trimmer
Thu Dec 17, 2009 1:12 am
Ah i see your point with the bbs. Ive been running some 9J et0 on the rear which sat pretty much perfect.
So am i righth in thinking (working from the table below) a 10J with an offset of -12 would give the same inner arch clearance (backspace), but stick out of the arch by an additional inch?
Kos
Thu Dec 17, 2009 1:18 am
sounds it
if they are RM's and you are just adding a deeper dish to the existing rim, the rear clearance will not change. just the outer arch will need work
IG Pukar.Designs
trimmer
Thu Dec 17, 2009 1:24 am
Thanks, i realise im kind of answering my own questions here, always gd to have a 2nd opinion tho.
They're not RM's... will be brand new and hopefully very :cool:
Kos
Thu Dec 17, 2009 1:26 am
looking forward to seeing this :D
IG Pukar.Designs
Thu Dec 17, 2009 11:50 am
Flare the arches away you go winkeye
Look forward to the pic's too, i like the sound of 10J rears :cool:
bootyman
Thu Dec 17, 2009 11:59 am
I've seen German E30's with 10's & Even 11's with minimum arch work. It all comes down to rubber and offset like you said, but if you want the car to be still half practical then it's better to have the arches done. I'm not a big fan of arches being rolled as 98% end up looking rippled. If you're gona do it then have them choped and flared properly so they look factory and still strong.
Lastly there is no point in running 10's if you dont have dish on the rims. You would be better off running 9's with minimum if any work at all!
I run 11's on my blue cab (Chopped arches) and 13's on the Rieger but only cause the kit allows you to. winkeye
da4x4turbo
Thu Dec 17, 2009 12:10 pm
bootyman wrote: Lastly there is no point in running 10's if you dont have dish on the rims.
Agreed, it's all about the dish:
Some Norwegian Dudes Car (9J Fronts and 9.5J Rears)
And of course who could forget Felgen-Garage's Show Car (9.5J Fronts and 11J Rears 8O )
Anyone who knows of an S50 B32/B30 E30 for sale, please let me know.
Thu Dec 17, 2009 12:24 pm
11J and the arches aren't heavily flared :o :o
trimmer
Thu Dec 17, 2009 6:41 pm
:o Thats impressive. Got a buyer sorted for my current wheels now so should be getting the ball rolling soon :D ...My thoughts at the moment are to hell with making them fit standard arches, go for the offset thats going to look best and then make the arches fit the wheels :twisted:
And yes, there should be copious amounts of dish :D Keep an eye out after xmas...
da4x4turbo
Thu Dec 17, 2009 9:40 pm
ImysE30 wrote:11J and the arches aren't heavily flared :o :o
Yeah, all I know about this car is that it has had arch modification. To what extent though I don't know. :D
Thu Dec 17, 2009 9:43 pm
Bootyman has 11J on his blue cabby and his arches are heavily flared, looks immense :drool:
leeparkes
Thu Dec 17, 2009 10:43 pm
trimmer wrote: Ive been running some 9J et0 on the rear which sat pretty much perfect.
What size tyres? and any pics?
trimmer
Fri Dec 18, 2009 11:15 am
225/40, on a 14" though so et0 and no arch worries :mad:
