Advanced Cleaning Guide
Introduction
xuyLVE <a href="http://yrvlpzqgqnwq.com/">yrvlpzqgqnwq</a>, [url=http://ockdsvhwalng.com/]ockdsvhwalng[/url], [link=http://slwvbfpdtmvl.com/]slwvbfpdtmvl[/link], http://enajjugeivpj.com/
Products Optional
- Bucket 2 (Optional)
- Meguirs Bug and Tar Remover
- Zaino clay bar
- Zaino CS (optional)
- Porter Cable/Orbital Buffer and accersories
- Varios buffers applicators and cloths
- Power hose, snowfoam lance and snow foam
- Meguirs Wheel Cleener - for regular wheels (do not use on proper polished surfaces)
- Meguirs/AutoGlym/Autosol metal polish (for you chromy deviants and proper polishing)
- Poorboys wheel sealent (not essential but two coats of thisand your next wash will be a piece of cake)
| Process | Basic Wash | Wash and Protect | Intensive clean and protect | Advanced |
| Snow Foam | N/A | N/A | N/A | X |
| Rinse | X | X | X | X |
| Wash | X | X | X | X |
| Dry | X | X | X | X |
| Clay | N/A | N/A | X | X |
| Porter Cable/Orbital | N/A | N/A | N/A | X |
| Panel Wipe | N/A | N/A | X | X |
| Z-aio/ZFX | X | X | X | X |
| Buff | X | X | X | X |
| Panel Wipe | N/A | X | X | X |
| Zaino Show Car Polish | N/A | X | X | X |
| Buff | N/A | X | X | X |
| Zaino CS | N/A | X | X | X |
Washing
Snow Foam
Claying
Panel Wipe
Z-aio / ZFX
- Z-aio - Zaino polish
- Z-aio - ZFX'd Zaino polish + Multiple ZFX'd Zaino polish applications
Zaino CS
Wheels
Washing
Polished Rims
Protecting
Q & A
Why Don't I use a Sponge?
--March109 17:03, 22 July 2008 (UTC)--
