M20
Revision as of 05:17, 16 July 2008 by Blitz (talk | contribs)
M20B25 2.5 litre 12 Valve Engine
The M20 is an straight-6 piston engine of BMW.
The 12-valve, belt driven SOHC design was introduced in the 1977 BMW 520/6 and 320/6. With displacements ranging from 2.0 to 2.7 liters, it was the "little brother" to the larger BMW M30 engine. It was intended to replace the larger displacement 4-cylinder motors and was born out of BMW's conviction that a small six had more development potential than a large four (i.e. 2 liters+)
Powering the E21 and E30 3-Series, as well as E12, E28 and E34 5 Series cars, it was produced for nearly two decades, with the last examples powering the E30 325i touring built until sometime in 1993. By that time, the newer twin-cam M50 engines with 4 valves per cylinder had already been used in the E36 and E34 for a couple of years.
Three different head castings were used over the engine's production run. The earliest was #1264200 aka the "200". These were used in all e21 320/6 and 323i and e12 520/6 engines and later in the e28 and e30 eta engines (eta = "Power With Economy"). The next version was #1277731 aka the "731". This head was the same as the 200 but featured larger intake ports. The final version was #1705885 or "885" introduced in the 325i. Ports were further enlarged, valves were larger and the combustion chamber was redesigned to improve flow and thermodynamic efficiency.
Engine Specs
Engine Displacement Power Torque Redline Year M20B20 2.0 L (1990 cc/121 in³) 92 kW (123 hp) @ 5800 165 N·m (121 ft·lbf) @ 4000 1981 92 kW (123 hp) @ 5800 170 N·m (125 ft·lbf) @ 4000 1981 95 kW (127 hp) @ 6000 174 N·m (128 ft·lbf) @ 4000 6200 1985 95 kW (129 hp) @ 6000 164 N·m (120 ft·lbf) @ 4300 6200 1986 M20B23 2.3 L (2316 cc/141 in³) 102 kW (143 hp) @ 5300 205 N·m (151 ft·lbf) @ 4000 6500 1982 110 kW (139-150 hp) @ 6000 205 N·m (151 ft·lbf) @ 4000 6500 1983 M20B25 2.5 L (2494 cc/152 in³) 126 kW (168 hp) @ 5800 226 N·m (166 ft·lbf) @ 4000 6700 1985 120 kW (170 hp) @ 5800 215 N·m (158 ft·lbf) @ 4000 6700 1985 125 kW (168 hp) @ 5800 222 N·m (163 ft·lbf) @ 4300 6700 1987 M20B27 2.7 L (2693 cc/164 in³) 92 kW (121 hp) @ 4250 240 N·m (177 ft·lbf) @ 3250 4500 1983 95 kW (127 hp) @ 4250 240 N·m (177 ft·lbf) @ 3250 4500 1986 90 kW (120 hp) @ 4250 230 N·m (169 ft·lbf) @ 3250 4500 1985 95 kW (127 hp) @ 4800 230 N·m (169 ft·lbf) @ 3200 4500 1986
Other variations
  • M20b20
  • M20b23
