M40 Timing Belt Change
Revision as of 06:58, 15 July 2008 by Hoshy (talk | contribs)
M40 Timing Belt Change (Originally Submitted on the E30 Zone by Gwynleym10)
Please note that this car had air - con so ignore the extra pipes / slightly bigger radiator + compressor.
Take the fan cowling off:
Pile of bits...
Old belt:
I then changed the rollers and then tensioners this is so obvious how to do it - you undo the bolts! Re-fit a new belt belt:
Starting from the bottom:
Tighten it up:
Fitting is the reverse of removal.....!
