BMW Dealership Maintenance - Inspection 1
Revision as of 13:05, 29 June 2008 by Hoshy (talk | contribs) (New page: INSPECTION 1 Engine Compartment: * Check and adjust valve clearance (M20) * Change oil and oil filter. * Check battery acid level and correct if needed...)
INSPECTION 1
Engine Compartment:
     Check coolant level and inspect system for leaks.
     Check steering fluid and brake/clutch fluid level.
     Check windshield washer fluid level.
     Check ATF fluid and LAD level (if equipped).
     Lubricate throttle linkage
Undercarriage:
     Check transmission for external leaks.
     Check manual transmission level, add if needed.
     Check final drive fluid level, add if needed.
     Check fuel lines, fuel tank and all connections for leaks.
     Inspect exhaust system.
     Check steering box and steering linkages for leaks and excess play.
     Inspect brake callipers, discs and brake pad thickness.
     Inspect brake hoses and lines for damage or leaks.
     Check handbrake, adjust cable if needed.
     Inspect front suspension and wheel bearings for play.
     Inspect wheels, tyres and adjust tyre pressures.
     Check spare tyre pressure.
Body and Interior:
     Lubricate door hinges, hood latch and bonnet hinges.
     Check operation of exterior/interior lights (including glove box, engine compartment… ).
     Check headlight aiming.
     Check condition and function of seat belts.
     Check operation of washer system.
     Check wiper blades condition.
     Check active check control panel for faults.
     Check function of air conditioning. Check refrigerant charge at sight glass.
     Tighten A/C compressor mounting bolts.
     Tighten nuts and bolts for door locks and striker plates.
     Replace intake dust/pollen micro filter in A/C unit.
     Replace batteries for alarm/remote control in master key (if equipped).
Road Test:
     Check braking performance, steering, HVAC, transmission and mirrors.
