Windscreen Wiper faults
Revision as of 20:24, 30 June 2010 by Gruelius (talk | contribs)
Potential Cure For Stuttering Windscreen Wipers On Intermittent Setting
Originally Written & Photographed by Peter Laing (PeteE30tourer)
One of the most annoying “features” of my cherished E30 is that the wipers barely manage to stutter across the screen when on the intermittent or single wipe settings, even though they work fine on normal or fast modes. Having read several posts on the E30zone forums from others with the same problems, it’s obvious that this is a common problem. I’d read about a possible cure for this in the responses on the forum, so thought I’d give it a go and take a few photos in the process to share it with others. So, here’s what I did.
Step 2 – Remove the Wiper Mechanism First thing you’ll note is that the nut holding on the wiper mechanism isn’t easily accessible, so, get in the car, turn on the ignition and set the wipers wiping, but turn off the ignition as they get to the vertical position, thus stopping them there. The motor/mechanism will now look something like this:
Step 4 – Removing the motor
  1. Clip the plastic cover back on the round section of the wiper motor
  1. Put the overall plastic cover back on the motor
  1. Put the motor back in the compartment
  1. Bolt it to the bracket with the three smaller bolts
  1. Bolt the bracket back to the bulkhead with the three larger bolts (Note that these have elongated holes to allow some lateral adjustment – try to get them back in the original positions to avoid upsetting the mechanism in any way.)
  1. Reconnect the connector (good opportunity to use some contact cleaner!)
  1. Put back the sound-deadening panel
  1. Reconnect the wiper mechanism in the same position as it was taken off
  1. Turn on the ignition and check the wipers park correctly – if not see below
