Category:Incomplete Articles
Revision as of 23:09, 28 September 2015 by Willnz (talk | contribs)
1. tap and clean head bolt threads in block making sure they are cleaned right to the bottom of the thread- remove any muck in the bottom of the thread bore.
2. If using new rings, it is very important to check gaps in bores first before assembly onto pistons.
3. Torque up crank and check rotation and end float before assembling pistons/rods.
4. Detail how to install new oil ring onto piston and how to orientate all ring joints when installing into block.
5. Check, but preferably replace frost plugs.
etc...
Maybe mention (but not applicable for assembly of the M20 motor)- when installing piston/rod assembly, if the rods have studs, a sleeve must be placed over the stud to protect the crank journal from possible damage in the installation process.
Honing.
Refaced.
Six brand new Mahle pistons.
Removing the circlip.
Once you get the first circlip in, you need to grease the piston and gudgeon pin with assembly lube.
Some more assembly lube on the bearing faces.
Some assembly lube on the crank.
Prepare the piston and rod with some assembly lube on your new rod bearings. Put your ring compressor around the piston. ??I'm told to keep the ring gaps away from the thrust face. Try and line the ring gaps up with the gudgeon pins.??
Some assembly lube on the rod cap, Be sure to put the cap on the right way around. (this is where your markings come in handy)
The the rod bearing cap bolts then get done up a additional 70 degrees starting in the middle working your way to the ends.??
Now add the oil pump and do that up to 16ft-lbs.
Once its all done up to specs, it's time to turn it over and rotate the whole thing.. It should all spin pretty easy with a little bit of effort... (that is if you ordered the correct size bearings)
Now that that's all done, it's time to prepare the front and rear engine plates. The rear one carries the rear main seal and the front one doubles as the timing case, it also carries two oil seals one for the crank and the other for the oil pump drive.
First thing to do is knock out the seal in the rear engine plate: use a blunt chisel and work your way around being very careful not to damage the plate. If you damage it you might end up with a oil leak so take your time... If you have a big socket or pipe you can press it our which is the best method.. ( I didn't have anything that big)
Next thing to do is slide the oil pump shaft in with some pre assembly lube.
And then install the timing case on the front of the engine with a brand new gasket, be careful not to snare the oil seals as, if they get damaged, you will have leaks.. I pack everything up with grease to make it easier. While your at it put the water pump on with its gasket.
Now add the small crank pulley sliding it over the key way in the crank. Also the oil pump pulley and timing belt.
You will know when it's right as piston one and six will be right up the top of their bores.
