Category:Incomplete Articles
Building a m20 6 cylinder engine... by Mike Jermyn
Honing.
Refaced.
Six brand new Mahle pistons.
Removing the circlip.
Once you get the first circlip in, you need to grease the piston and gudgeon pin with pre assembly lube.
