Category:Incomplete Articles
[img]http://i39.photobucket.com/albums/e200/m_jermyn/Building%20a%20m20b27/Engine1.jpg[/img]
Honing.
http://i39.photobucket.com/albums/e200/m_jermyn/Building%20a%20m20b27/Engine2.jpg
Refaced.
http://i39.photobucket.com/albums/e200/m_jermyn/Building%20a%20m20b27/Engine3.jpg
This is typically how it will be strait from the machine shop.
Now if you are using your old piston and rod combo you can skip tis step.
Six brand new Mahle pistons.
Removing the circlip.
Time to drop in the crank, be very careful as even though they are heavy and steal they are fragile and if dropped they will break, Its best to use two people.
When them down be sure to use some anti seize on the threads. I don't torque them up only nip them up.
The rod bearing cap bolts all get done up to 15ft-pnds starting in the middle and working your way to the ends.
Now its time to prep the sump, I use a gasket sealant as well as the gasket... I find the sealant holds the gasket when lining everything up and makes life a little easier, its also meant to fill in the finest of imperfections between the gasket and sump meaning no chance of leeks.
Bolt it all up using the 10mm bolts to 11ft-pnds.
