EWS
Revision as of 17:36, 1 August 2013 by Grrrmachine (talk | contribs)
  • ECU
  • EWS module
  • Key
  • Ignition Barrel Ring
  • Send/Receive module (under the steering column)
  • Loom
The ECU, EWSII and key come as a set. If you have the key and EWSII box, they can be reprogrammed to suit a different ECU by someone with the right equipment. So it is best to ensure you get all 3 components from the same car when purchasing, even see if there are spare keys to be had.
M50
M52
Disabling
You didn't think it would be that easy to disable the EWS, did you? And that we'd put that info on a public forum? Good.
The good news is that if you really don't want the hassle of the EWS system, it is possible to deactivate it by swapping in a non-EWS ECU. Essentially, this comes down to replacing the 413 silver label ECU (as fitted to the E36) with the purple-label 413 ECU.
There are other websites (and previously this one) which advocated snipping a green or black/purple wire on your engine loom. We really don't recommend this, unless you fancy cutting off power to your car's injectors.
Reference
Learn more about the EWS system
