Brake Upgrades
Basic checks
Always ensure that your braking components are in full working order and good condition before embarking on any upgrade. Check that the calipers are in full working order (no sticking pistons, seals etc) and the brake hoses are not worn or cracked. Also check the servo is working properly if fitted (a duff servo normally gives you a hard pedal with a lack of braking force) and that the master cylinder seals are good (leaking seals give you a soft pedal, often slowly "sinking" if held under pressure).
Aspects of braking
Brake Power
Unsprung mass
Rotational mass
Fade (pad) resistance
Fade (fluid) resistance
Heat reduction
Disc warping resistance
Performance cooling
5-Lug Conversion
The E30 M3 was fitted with completely different hubs, allowing it to take 5-lug wheels instead of the standard 4x100 E30 wheels. This allows for much larger wheels, and therefore bigger discs and callipers to fit inside them. Converting to a 5-lug setup is a popular option for serious performance driving.
Pads
First would be upgrading the pads as you get some easy extra torque and fade resistance (EBC Red, Mintex M1144/1155, Ferodo DS2500 or similar pads for fast road/light trackdays or EBC Yellow/Blue or similar for more serious track use) - of course all the OEM components need to be checked over at the this stage, including the cooling ducts. Fit fresh standard brake fluid and new standard discs (worn discs have less thermal mass and won't bed in properly with new pads).
Hoses
Next would be increasing the resistance to the extra heat and pressure the pads can create by fitting stainless braided hoses (like Earls/Goodrich etc) and upgrading the existing brake fluid (like ATE Superblue, or Castrol SRF for a road/trackday oriented car).
A common question regarding brake hoses is "Which kit - 4 or 6 line?" The answer is simple; 4 Line kit for drums, 6 Line kit for rear disks. All ABS-equipped cars have rear discs, so you'll need the 6 Line kit if you have ABS.
Discs
Standard discs do the job for most applications perfectly well but do decrease their thermal mass over time, leading to decreased performance. There is NO NEED to get drilled and/or grooved or funny coloured discs, unless you like the look.
If you want a proper upgrade, you need to increase the size of the discs. Here are the approximate sizes possible in each wheel size:
16" - 300mm (320mm in some motorsport alloys). 302mm disks with 4 pot callipers can be made to fit under 16" wheels, according to Baddave.
Bolt-on options
- The WMS 280mm (fits 15" BBS & 16" Alpina) and 298.5mm (fits 16" Hartge & AC Schnitzer) 4-pot kits which have custom 1.25" E30-specific pistons.
Master Cylinders
BMW
Calipers
If you're fitting bigger discs, you will need compatible calipers that can apply a greater braking force over the increased area of the disc. If you can't stretch your budget to the bolt-on options, then substantial savings can be made by sourcing callipers from other cars and fabricating your own mounts. Scavenging parts from other cars can save you serious cash.
Cars with 4pot callipers
- Aston Martin(various)-DB7
- Alfa Romeo GTV/166
- Audi Possibly RS2,S8,RS8
- BMW E38 730i, 735i
- BMW E31 840i,850i,850csi
- Ferrari (all newer models)
- Fiat Coupe
- Ford Focus RS
- Ford Sierra RS Cosworth 3dr
- Jaguar S type R
- Lancia Delta(integrale)
- Lancia Phedra
- Mazda RX-7
- Mitsibishi 3000GT
- Nissan 300ZX
- Nissan 350Z
- Peugeot 607(possibly)
- Peugeot 807(possibly)
- Peugeot 406 Coupe
- MG MGF
- Seat Cupra R (Ibiza,Leon)
- Subaru Impeza STI
- Toyota Hilux
- Toyota Celica GT4
- Toyota Supra
- TVR ( certain newer models)
