E30 Dyno Graphs
Revision as of 01:19, 12 November 2012 by Kedge (talk | contribs)
M10
Engine Zoner Power Torque Information Dyno Graph
M10B20 teamalsoran 200.2 BHP 156.7 lbft 2.0 M10
Ported 121 head
12.1 CR
45mm jenveys
M10B22 Turbo teamalsoran 316.5 BHP 346.9 lbft 2.2 litre m10 turbo
Schrick 284 cam
T34 turbo
M10B25 teamalsoran 240.7 BHP 207.2 lbft 2.5 litre m10
custon accratlie pistons in a 2.5 s14 bottom end m10 121 head 12.1CR schrick 336 cam 50mm jenvey throttle bodies
-*Lower Graph*-
M20
M20B25
M20B25 bss325i 185.7 BHP 196 lbft
M20B25 Simon 183.7 BHP 191 lbft
Redline - Standard
M20B25 clarko74 167.6 BHP 144 lbft A-Tech Chip
180k Miles on the engine.
M20B25 Hoobs 164.5 BHP 144 lbft Standard
M20B25 Hoobs 170.1 BHP 136 lbft
This is after a service & running a 'Speedtouch' wild chip
6 branch of unconfirmed origin
M20B25 gaszman 163 BHP 171 lbft Standard high comp prefacelift engine
M1.0 Motronic
M20B25 MattG 209 BHP 235 lbft Standard m20 2.5
Megasquirt
NOS on 91 octain petrol
M20B25 hongkongfuey 192.1 BHP 189.9 lbft
stock 2.5
cam
bbtb (home made)
hottuning manni (no x pipe)
m30 injectors and afm
home made intake elbow
dmcl chip
lightened flywheel
M20B25 nadz325i 189 BHP 173.5 lbft BTB 6 Branch
BBTB
ITG Induction Kit
Schrick 284/272 CAM
At the wheels figures.
|- |M20B25 Turbo |Turbo-Brown |269.9 BHP |240.3 lbft |Early 9.7:1 compression M20B25
Two Skyline turbos
6 throttles
Tubular manifolds
Twin 2" exhausts
Two cossie 2WD ICs |
M20B27
Alpina C2 2.7 Simon13 198 BHP 220 lbft Racing Dynamics 6 branch with full scorpion
M20B27 Oguz327 225.6 BHP 204.8 lbft 2.7 M20, fully lightened, balanced and blueprinted built by A Tech
285/285 cat camshaft
BTB 6 branch
BBTB
Rolling road remap
ITG filter
Full scorpion system
M1.3 Motronic + chip
M20B27 Megasquirt Oguz327 227.8 BHP 208.6 lbft 2.7 M20, fully lightened, balanced and blueprinted built by A Tech
BTB 6 branch
BBTB
Rolling road remap
ITG filter
M20B27 oakey 205.7 BHP 224 lbft 135mm rods
Standard head
Bexley Block
M20B27 ITBs & Megasquirt oakey 218.6 BHP 211.8 lbft 135mm rods
Alpina pistons
ETA crank
11.016:1 CR
ITBs
280/280 cat camshaft
mild head port
TPS only (Alpha-N algo)
M20B27 Daimlerman 178.3 BHP 191 lbft 525e Block
731 Head
Miller MAF
M20B27 Jimbob 200.4 BHP 199 lbft 525e Crank and Rods
High comp M20B25 pistons
325i block decked
Standard 325i head
Dbilas 284/272 with standard springs
BTB 6 Branch
A-Tech Chip
M20B27 DaveD 189.2 BHP 192.4 lbft ETA block
re mapped
pipercross intake
bbtb
magnex 6 branch
scorpion bbox
M20B28
M20B28 Bullet_Ride 182.6 BHP 193.8 lbft Schrick 284/272 with stock valve springs.
Block shaved 0.5mm
On a hot summer day with the car running rich because of a bad O2 sensor this is what was put down...
M20B28 stonesie 206 BHP 203 lbft B25 low comp pistons, block and head both skimmed (minimal on the head, 0.5mm on the block to retain standard squish) approx 9.7:1 CR
M52B28 crank
M20B20 rods
CatCams 273/273 with vernier
Lightweight flywheel
BBTB
M20B28 goosiegander 195.4 BHP 175.4 lbft M20 2 ltr block bored to 84.0mm
Single vanos M50B28 crank
M20 2 ltr conrods
885 headcasting
BBTB
2.8 Motronic chip
M20B28 MAF goosiegander 200 BHP 190.1 lbft M20 2 ltr block bored to 84.0mm
M20 2 ltr conrods
885 headcasting
BBTB
MAF Conversion
M20b28 Turbo Gunni 400.8 BHP 465 lbft M20B28 8:1 compression
60trim TCD T4 turbo
log manifold
1.1bar boost
M20B31
M20B31 reggid 220 BHP 218 lbft M20B31 - 3086cc
10.5:1CR
BTB2
BBTB
standalone
catcams 298/285
M30
M30B35 driftmonkey 206.5 BHP 213 lbft Standard
M30B35 B10 Alpina driftmonkey 257 BHP 285 lbft Alpina B10
M5 conrods
Larger valves
268 degree cam
Remapped ECU
M30B35 Turbo Toby_Unna 295.6 BHP 330 lbft Turbo Conversion
Megasquirt
M30B35 Andy335Touring 248 BHP 217 lbft Cam/head work/chip
M30B35 gareth 221 BHP 238 lbft Free flowing exhaust
compression increased from 9:1 to 10:1.
ignition etc are all unchanged at present.
LPG system, single point 37mm mixer, OMVL R90/e vap, leonardo ecu.
On petrol with mixer venturi removed - 221 bhp, 238 lb.ft
On petrol with mixer venturi fitted - 204 bhp, 223 lb.ft
On LPG with mixer venturi fitted - 183 bhp, 216 lb.ft
M40
M42
M42B18 agreen 147.6 BHP 136 lbft Green line: standard
Pink line: with Evolve Automotive chip fitted
M42B18 Magpie 152 BHP 135.8 lbft Evolve 18 bhp chip with k&n panel filter
M42B21 tim_s 198.3 BHP 172.9 lbft M47 crank
custom rods and forged JE pistons
fully lightened and balanced
late spec cyl head with +2mm valve throats, 3 angled seats, skimmed 0.2mm to give even higher CR
259/10.4 catcams
megasquirt 2 extra
Custom MLS HG, total seal rings, ARP rod bolts
serpentine belt, coil on plug
M50
M50B25 Monkey 217.3 BHP 200 lbft ECU chip by EAT
M30 air box
M50B25 Turbo craigieeb 452.3 BHP 445.5 lbft It's a standard 2.5 M50
ARP studs
MLS Gasket
440cc injectors
Borg Warner Turbo
External Tial wastegate
VEMS ecu
running 1.3 bar of boost (controlled By GReddy PRofec B-spec II boost controller)
M52
M52B28 DanThe 206.8 BHP 196.9 lbft M50 Inlet Manifold
M52B30 DanThe 234.1 BHP 239 lbft M52 steel liner block
E46 330i crank gear
M50 Inlet Manifold
S14
S14B25 maxfields Dad 268 BHP 194.4 lbft Schrick 284 cams
head work
c/f airbox
dta and other goodies
|- |S14B24 Turbo |teamalsoran |490.3 BHP |439.9 lbft |2.4litre s14 turbo
2.3 215bhp top end
Custom pistons
T38 turbo on low boost
Huge intercooler |*spikes in graph low down was a gearchange*
|- |S14B26 |teamalsoran |276.4 BHP |235.8 lbft |2.6 litre 275bhp S14
95.34mm Wosner pistons
11.5:1 CR
91mm stroke steel crank
Ported head
Schrick 292/284 cams | -*Upper Graph*-
S50
S30B30 billgatese30 293.5 BHP 248.5 lbft Standard.
Run 1 -
Run 2-
