E30 Dyno Graphs
M10
M1020 - teamalsoran
2.0 M10
Ported 121 head
12.1 CR
45mm jenveys
M1022 Turbo - teamalsoran
2.2 litre m10 turbo
Schrick 284 cam
T34 turbo
M10B25 - teamalsoran
-*Lower Graph*-
240bhp 2.5 litre m10
Custon Accratlie pistons in a 2.5 s14 bottom end
M10 121 head
12.1CR
Schrick 336 cam
50mm Jenvey throttle bodies
M20
M20B25
M20B25 - bss325i
M20B25 - Simon
Redline - Standard
M20B25 - Hoobs
Standard
M20B25 - Hoobs
This is after a service & running a 'Speedtouch' wild chip and a 6 branch of unconfirmed origin
M20B25 - nzbimmer
Standard engine.
At the wheels figures.
m20b25 - hongkongfuey
stock 2.5
cam
bbtb (home made)
hottuning manni (no x pipe)
m30 injectors and afm
home made intake elbow
dmcl chip
lightened flywheel
M20B25 - nadz325i
BTB 6 Branch
BBTB
ITG INduction Kit
Schrick 284/272 CAM
Before MAF(with schrick, BBTB, 6 Branch and ITG);
180.6 bhp @ 6221 rpm
164.1 lb.ft @ 5314 rpm
After MAF;
189 BHP @ 6332rpm
173.5 lb.ft @ 5357 rpm
M20B27
M20B27 - Simon13
Racing Dynamics 6 branch with full scorpion
198bhp and 220lbs
M20B27 - Oguz327
2.7 M20, fully lightened, balanced and blueprinted built by A Tech
285/285 cat camshaft
BTB 6 branch
BBTB
Rolling road remap
ITG filter
Full scorpion system
M1.3 Motronic + chip
M20B27 - Oguz327 (Megasquirt)
BTB 6 branch
BBTB
Rolling road remap
ITG filter
M20B27 - oakey
Standard head
Bexley Block
M20B27 - oakey
135mm rods
Alpina pistons
ETA crank
11.016:1 CR
ITBs
280/280 cat camshaft
mild head port
TPS only (Alpha-N algo)
M20B28
M20B28 - Bullet_Ride
Schrick 284 with stock valve springs.
Block shaved 0.5mm
On a hot summer day with the car running rich because of a bad O2 sensor this is what I put down...
M52B28 crank
M20B20 rods
CatCams 273/273 with vernier
Lightweight flywheel
BBTB
M20B28 - goosiegander
M20 2 ltr block bored to 84.0mm
Single vanos M50B28 crank
M20 2 ltr conrods
885 headcasting
BBTB
2.8 Motronic chip
M20B31
M20B31 - reggid
M20B31 - 3086cc
10.5:1CR
BTB2
BBTB
standalone
catcams 298/285
M30
M30B35 - driftmonkey
Standard
M30B35 B10 Alpina- leeparkes
257bhp @ 5450rpm BUT it made 285 lb ft @ 4200rpm.
Alpina B10
M5 conrods
Larger valves
268 degree cam
Remapped ECU
M30B35 Turbo- Toby_Unna
Turbo Conversion
Megasquirt
M40
M42
M42B18 - Magpie
Evolve 18 bhp chip with k&n panel filter
M42B21 - tim_s
M47 crank
custom rods and forged JE pistons
fully lightened and balanced
late spec cyl head with +2mm valve throats, 3 angled seats, skimmed 0.2mm to give even higher CR
259/10.4 catcams
megasquirt 2 extra
Custom MLS HG, total seal rings, ARP rod bolts
serpentine belt, coil on plug
M50
M50B25 - Monkey
ECU chip by EAT
M30 air box
M52
M52B28 - DanThe
M50 Inlet Manifold
E46 330i crank gear
M50 Inlet Manifold
S14
S14B26 - teamalsoran
2.4litre s14 turbo
2.3 215bhp top end
Custom pistons
T38 turbo on low boost
Huge intercooler
- spikes in graph low down was a gearchange*
-*Upper Graph*-
2.6 litre 275bhp S14
95.34mm Wosner pistons
11.5:1 CR
91mm stroke steel crank
Ported head
Schrick 292/284 cams
S50
S50B30 - billgatese30
Standard.
Run 1 -
Run 2-
