Nuts and Bolts
Revision as of 07:23, 17 July 2012 by Grrrmachine (talk | contribs)
The very definition of detail. We've compiled one complete list of ALL the nuts and bolts you need for assembling your E30. We spoil you, we really do.
To confirm any of these parts, or for data on the other items pictured, check out the Parts Catalogues.
To make sure all these nuts and bolts are correctly tightened, check out our Torque Settings.
Data gathered by Jozi.
Front axle
No. Part Part Number Size Quantity
2 Flat washer 31 11 1 114 348 A10,5X22 4
3 Hex bolt 31 11 1 137 887 M10X1.5X65 4
5 Self-locking hex nut 31 10 6 774 714 M14X1,5-05 ZNS3 2
6 Self-locking hex nut 32 21 6 769 539 M12X1.5-05 ZNS3 2
9 Flat washer 31 11 1 114 348 A10,5X22 4
10 Hex bolt 31 11 1 137 888 M10X1.5X40 4
Front ARB
6 Hex bolt 07 11 9 901 120 M8X1.25X20-ZNS 2
7 Hex nut 07 11 9 922 856 M8X1.25-ZNS 2
10 Hex bolt 07 11 9 912 506 M8X1.25X45 2
11 Self locking hex nut 07 12 9 906 196 M8X1.25-8-ZNNI SI 2
12 Flat washer 31 11 1 114 348 A10,5X22 2
Rear ARB
4 Hex Bolt with washer 07 11 9 915 066 M8X16-Z3 2
6 Hex Bolt 07 11 9 912 501 M8X1.25X43 2
7 Self-locking hex nut 07 12 9 906 196 M8X1.25-8-ZNNI SI - Chrome-free CR(VI) 2
11 Self-locking collar nut 07 11 9 904 295 M8X1.25-8-ZNS3 - Chrome-free CR(VI) 2
4 Wave washer 07 11 9 932 112 B10-ZN 6
5 Hex bolt 07 11 9 914 114 M10X25-8.8 ZN 4
7 Screw plug with O-ring 33 11 7 525 064 M22X1,5-ZNS3 2
9 O-ring 33 11 1 206 166 27,1X22,3X2,4 1
12 Hex bolt 07 11 9 913 117 M6X10-8.8 ZNS 2
14 Hex bolt 07 11 9 914 636 M12X1,5X55 1
15 Flat washer 07 11 9 931 021 A13 2
16 Self-locking hex nut 7 12 9 900 047 M12X1,5-10-PHR 1
17 Flat Washer 33 33 1 120 662 A12.5 4
18 Hex bolt 07 11 9 911 694 M12X1,5X25 4
Driveshafts
3 Fillister head screw 07 11 9 919 620 M10X50 12
Rear Beam
6 Inner hex bolt 33 31 1 129 676 M8X22 4
7 Collar nut 33 33 1 126 136 M14X1,5 2
14 Fillister head screw 07 11 9 919 913 M6X1.0X12 4
15 Wave washer 07 11 9 932 099 B6 (ZNS3) 4
Propshaft
3 Hex Bolt 26 11 1 225 054 M10X1.5X50/8.8 3
4 Hex Bolt 26 11 1 225 054 M10X1.5X50/8.8 3
5 Self-locking hex nut 07 12 9 964 672 M10 6
16 Self-locking hex nut 07 12 9 964 672 M10 4
Front Brakes
3 Hex Bolt 34 11 1 118 948 M12X1,5X32 4
6 Self-locking hex bolt 34 11 1 154 445 M8X1.25X21 4
Disc
Hex Bolt with washer 34 11 1 156 427 M6X1.0X8 6
Inner hex bolt 34 11 1 123 072 M8X1.25X12 2
Rear Brakes
4 Hex Bolt 34 21 1 153 937 M10X1.5X30 4
12 Inner hex bolt 34 11 1 123 072 M8X1.0X12 2
14 Hex Bolt with washer 34 11 1 156 427 M6X1.0X8 4
Handbrake
Hex Bolt 34 41 1 121 511 M8X1.25X22 4
Rear Shock
Flat Washer 07 11 9 931 021 A13 2
Hex Bolt 07 11 9 914 647 M12X1,5X65 2
