Wipers
Revision as of 07:11, 16 July 2012 by Grrrmachine (talk | contribs)
Windscreen Wipers
Wipers
Motor
Mechanism
Washer Jets
Heated washer jets were fitted as part of the Heated package. Learn more about retrofitting heated washer jets.
Tank
Pump
Control Stalk
Relay
Rear Wash-Wipe
Wiper
Motor
Pipes
Pump
Tank
Switch
The system is controlled by two switches, offering a wash or a timed wipe setting. Cleaning fluid is sprayed from a nozzle mounted to the wiper arm, and will only operate when the wiper is moving; therefore, pressing the wash button should make the wiper sweep three times.
Headlight Wipers
Stuttering Wipers
Main article: Intermittent Wiper Faults
