Aircon
Compressor
The compressor itself does not pump continuously. Instead, it is activated based on the internal pressure of the system and whether or not the Aircon is turned on. That way, the compressor does not sap precious power, and therefore fuel, from the engine when it's not wanted.
Since the refrigerant is constantly changing between a gas and a liquid throughout the system, by the time it meets the compressor it is in a gaseous form. The compressor, unsurprisingly, compresses this gas which makes it hot, before pumping it on to the condensor.
Condenser
The condenser's location and construction make it one of the most fragile elements of the installation. Not only can it be damaged by road debris, but it is also exposed to road spray at its base. This makes them the prime source of refrigerant leaks and therefore total system failure.
Fan
Evaporator
Expansion Valve
Receiver Drier
Pipework
Refrigerant
R-134a Kit
The R-134a kit includes a new receiver drier, valves, pressure switch and some O-rings, like so:
Aircon Clutch
Pressure Switch
Installation
Aircon Won't Turn On
