Aircon
Aircon was fitted as an optional extra to E30s as early as 1984, and the system remains largely the same throughout the E30 production run. The system is based around a sealed refrigerant gas, just like your fridge at home. I won't explain the science, but as the refrigerant is converted from a gas to a liquid it gains heat; as it goes back to a gas it loses heat and cools, and it is this cooling effect we make use of. It's therefore essential that our system be completely sealed, to keep the refrigerant inside.
The system uses a number of components to compress, liquify, filter and evaporate the refrigerant. Expansion_Valve|Valves regulate the flow of refrigerant through the pipework, and the whole system is controlled from a switch on the dashboard. A pressure switch monitors the condition of the coolant and determines whether or not the compressor needs to be engaged; if required, the clutch locks to drive the compressor.
Compressor
Condensor
Receiver Drier
Evaporator
Expansion Valve
Pipework
Refrigerant
R-134a Kit
Electric Fan
Aircon Clutch
Pressure Switch
Installation
Aircon Won't Turn On
