M20
Revision as of 04:39, 21 May 2010 by Willnz (talk | contribs) (Protected "M20" [edit=sysop:move=sysop])
M20B25 2.5 litre 12 Valve Engine
The M20 is an straight-6 piston engine of BMW.
The 12-valve, belt driven SOHC design was introduced in the 1977 BMW 520/6 and 320/6. With displacements ranging from 2.0 to 2.7 liters, it was the "little brother" to the larger BMW M30 engine. It was intended to replace the larger displacement 4-cylinder motors and was born out of BMW's conviction that a small six had more development potential than a large four (i.e. 2 liters+)
Powering the E21 and E30 3-Series, as well as E12, E28 and E34 5 Series cars, it was produced for nearly two decades, with the last examples powering the E30 325i touring built until sometime in 1993. By that time, the newer twin-cam M50 engines with 4 valves per cylinder had already been used in the E36 and E34 for a couple of years.
Three different head castings were used over the engine's production run. The earliest was #1264200 aka the "200". These were used in all e21 320/6 and 323i and e12 520/6 engines and later in the e28 and e30 eta engines (eta = "Power With Economy"). The next version was #1277731 aka the "731". This head was the same as the 200 but featured larger intake ports. The final version was #1705885 or "885" introduced in the 325i. Ports were further enlarged, valves were larger and the combustion chamber was redesigned to improve flow and thermodynamic efficiency.
Engine Specs
Models
Other variations
  • M20b20
  • M20b23
