Fuse Box
Revision as of 12:59, 16 March 2012 by Grrrmachine (talk | contribs)
Fuses
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
7.5 7.5 15 15 30 7.5 15 30 15 7.5 7.5 7.5 7.5 7.5 7.5
Left High Beam Headlight
Relay K3
Right High Beam Headlight
Relay K3
Auxilliary Fan 91C
Relay K1
Flashing Turn Indicators Wipe-Wash Headlight Cleaning
Intensive Cleaning Relay K10
Brake Lights
(15A if 3rd brake light used) Cruise Control Map Lights
Horn
Relay K2
Heated Rear Window Selector Lever Position Indicator
(Auto Box)
Instruments
OBC Reverse Lights Service Indicator
Fuel Pump
Fuel Supply Pump
Radio
Check Control Instruments
Left Low Beam Headlight
Relay K4
Right Low Beam Headlight
Relay K4
Rear Fogs
Relay K4 Off when Headlight beams are selected Relay K9
16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
15 30 30 7.5 30 7.5 7.5 7.5 15 30 15 30 30 7.5 7.5
Seat Heating
Relay K5
Sliding Roof
Relay K5 Electric Windows
Auxiliary Fan 99C
Relay K6
Mirror Control
Mirror Heating Relay K7
Heater Blower
Air Con Relay K7
Interior
Glove Box and Boot lights Torch Clock Radio Memory OBC
Left Rear and Parking lights Right Rear and Parking lights
Licence Plate lights Instrument lights
Hazards Not in use
12V Live
Rear Wash-Wipe Central Locking
Door Lock Heating OBC Horn Sound System
Cig Lighter
Elec Aeriel Door open window lifts
Left Fog Light
Relay K8
Right Fog Light
Relay K8
Relays
Main article: Relays
As well as fuses, the Fuse box also contains electromagnetic switches called Relays. These allow a low-power circuit to turn on a high-power circuit, without the risk of high voltage running through the switch your fingers are touching. There are ten of these relays in the Fuse Box, outlined in the picture below. Their functions are connected to the fuses in the table above.
