Fuse Box
Fuses
| Left High Beam Headlight
Relay K3 |
Right High Beam Headlight
Relay K3 |
Auxilliary Fan 91C
Relay K1 |
Flashing Turn Indicators | Wipe-Wash Headlight Cleaning
Brake Lights
Horn
Relay K2 |
(Auto Box) |
Instruments | Fuel Pump
Fuel Supply Pump |
Relay K4 |
Right Low Beam Headlight
Relay K4 |
Rear Fogs
Relay K4 Off when Headlight beams are selected Relay K9 |
| Seat Heating
Relay K5 |
Sliding Roof
Relay K5 Electric Windows |
Auxiliary Fan 99C
Relay K6 |
Mirror Control
Mirror Heating Relay K7 |
Heater Blower
Air Con Relay K7 |
Hazards | Not in use
12V Live |
Rear Wash-Wipe | Central Locking
Cig Lighter
Left Fog Light
Relay K8 |
Right Fog Light
Relay K8 |
Relays
Main article: Relays
As well as fuses, the Fuse box also contains electromagnetic switches called Relays. These allow a low-power circuit to turn on a high-power circuit, without the risk of high voltage running through the switch your fingers are touching. There are ten of these relays in the Fuse Box, outlined in the picture below. Their functions are connected to the fuses in the table above.
