Relays
Revision as of 19:29, 20 December 2011 by Grrrmachine (talk | contribs) (New page: As a key part of the Loom, a number of relays are fitted to various parts of your Electrical system. {|class="wikitable" !Function !Relay !Location |- |Headlight Cleaners |1 |rows...)
Function Relay Location
Intensive Cleaning 2
DME 3
Cruise Control 4
Idle Speed 5
Ignition Advance 6
Igntion Control 7
Fuel Pump 8
Oxygen Sensor heating 9
AC Blower 10
AC 11
Flashing relay 12
ABS Overvoltage 13
ABS Control 14
Hydraulic Control 15
Valve relay 16
Motor relay 17
Ignition advance (up to 1987) 18
Idle stabilisation 19
L-Jetronic Master relay 20
Alarm system relay 21
Power Window relay 22
Starter interlocking relay 23
Central Locking 24
Inside Light Delay 25
Bulb tester for check control 26
Independent electronic
transmission conrtrol
27
