The Diagnostic Plug is a multipin socket in your engine bay, allowing you to perform some basic engine functions.
Pinouts
Early Style 15-Pin Diagnostic plug
| Pin
Wire Gauge
Colour
Function
| 1
1.5
BK
Ground Distribution, G103
| 4
0.5
BR/VI
Gauges/Warning Indicators, Coolant Temperature Sender
| 6
0.75
GY/BU
Not Used
| 7
0.75
WT/BU
Service Interval Indicator, Service Interval Processor (Reset)
| 8
0.5
YL
Ignition, TDC Sensor
| 9
SHIELD
| 10
0.5
BK
| 11
2.5
BK/YL
Starter, Start Signal (50)
| 12
0.75
BU
Charge, Alternator (D+)
| 13
1
GN
Ignition, Ignition Coil
| 14
2.5
RD
Charge System, Alternator (30)
| 15
1.5
GN/YL
Idle Speed Control, Idle Speed Control Unit
Large Style "Pacman" Diagnostic plug
| Pin
Wire Gauge
Colour
Function
| 1
1
BK
Ignition Coil, Motronic Control Unit
| 6
0.5
WT/BK
SRS Connector (Not Used)
| 7
0.5
WT/GN
| 11
2.5
BK/YL
| 12
0.75
BU
| 14
2.5
RD
Battery
| 15
0.5
WT/YL
Motronic Control Unit (RXD)
| 16
1.5
GN/WT
Oxygen Sensor
| 18
0.5
GN/BU
Motronic Control Unit (Programming Voltage)
| 19
1.5
BR
Ground Distribution (G103)
| 20
0.5
WT/VI
Motronic Control Unit (TXD)
