Z3 short shifter conversion
Revision as of 18:04, 21 November 2011 by Grrrmachine (talk | contribs)
Choice of Rod
A number of gear levers are available from the Z-range of cars to change the feel of your gearstick, shown below.
The important thing to look for is the space between the ball joint (in the line) and the selector rod joint (far right). The longer the distance, the shorter the shift.
As you can see, there are a number of options available, but not all of them are practical. The Z3 2.8 lever gives a very switchy feel to the gearstick, with very little needed to shift from 1st to 2nd gear. The Z3-M is the shortest of them all, to the point of putting your synchromesh gears at risk; for that reason we do not recommend the use of this lever.
Parts Required
Description Part Number Price (£) Quantity Total Price (£)
Recondition Parts Gear selector rod joint 25 11 7 501 309 14.39 1 14.39
Dowel pin 23 41 1 466 134 0.29 1 0.29
O ring 25 11 1 221 243 0.31 2 0.62
Spacer ring 25 11 1 220 199 0.12 1 0.12
Circlip 07 11 9 932 863 0.12 1 0.12
Short Shift Parts Gear lever 25 11 7 527 252 36.46 1 36.46
Spacer ring 24 11 1 220 439 0.30 2 0.60
Circlip 25 11 7 571 899 0.37 2 0.74
Shift lever bearing 25 11 1 220 600 6.08 1 6.08
New gasket Exhaust gasket 18 30 1 711 969 7.96 1 7.96
Total 67.38
