BMW Dealership Maintenance - Inspection 1
Revision as of 05:16, 23 September 2011 by Grrrmachine (talk | contribs)
INSPECTION 1
Engine Compartment:
Check and adjust valve clearance (M20) *
Change oil and oil filter. *
Check battery acid level and correct if needed. *
Check coolant level and inspect system for leaks. *
Check steering fluid and brake/clutch fluid level. *
Check windshield washer fluid level. *
Check ATF fluid and LAD level (if equipped). *
Lubricate throttle linkage
Undercarriage:
Check transmission for external leaks. *
Check manual transmission level, add if needed. *
Check final drive fluid level, add if needed. *
Check fuel lines, fuel tank and all connections for leaks. *
Inspect exhaust system. *
Check steering box and steering linkages for leaks and excess play. *
Inspect brake callipers, discs and brake pad thickness. *
Inspect brake hoses and lines for damage or leaks. *
Check handbrake, adjust cable if needed. *
Inspect front suspension and wheel bearings for play. *
Inspect wheels, tyres and adjust tyre pressures. *
Check spare tyre pressure.
Body and Interior:
Lubricate door hinges, hood latch and bonnet hinges. *
Check operation of exterior/interior lights (including glove box, engine compartment… ). *
Check headlight aiming. *
Check condition and function of seat belts. *
Check operation of washer system. *
Check wiper blades condition. *
Check active check control panel for faults. *
Check function of air conditioning. Check refrigerant charge at sight glass. *
Tighten A/C compressor mounting bolts. *
Tighten nuts and bolts for door locks and striker plates. *
Replace intake dust/pollen micro filter in A/C unit. *
Replace batteries for alarm/remote control in master key (if equipped).
Road Test:
Check braking performance, steering, HVAC, transmission and mirrors.
