Technical
Revision as of 19:28, 22 September 2011 by Grrrmachine (talk | contribs)
Engines
Main article: Engines
Name Volume Engine Valvetrain Fuel Output Torque Engine code Years
316 1766cc 4cyl SOHC 8V Petrol 99hp (66kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M10B18 1982–1990
316i 1596cc 4cyl SOHC 8V Petrol 102hp (75kW) @4500 rpm 105ft/lb (140Nm) @4250 rpm M40B16 1988–1995
318 1766cc 4cyl SOHC 8V Petrol 104hp (77kW) @4500 rpm 103ft/lb (140Nm) @4250 rpm M10B18 1982–1990
318i 1796cc 4cyl SOHC 8V Petrol 113hp (85kW) @4500 rpm 122ft/lb (165Nm) @4250 rpm M40B18 1987–1995
318iS 1766cc 4cyl SOHC 8V Petrol 140hp (104kW) @4500 rpm 127ft/lb (172Nm) @4250 rpm M42B18 1989–1991
320i 1990cc 6cyl SOHC 12V Petrol 123hp (92kW) @5800 rpm 125ft/lb (170Nm) @4000 rpm M20B20 1982–1985
320i 1990cc 6cyl SOHC 12V Petrol 127hp (95kW) @6000 rpm 120ft/lb (164Nm) @4300 rpm M20B20 1985–1991
320iS 1990cc 4cyl DOHC 16V Petrol 192hp (143kW) @6750 rpm 155ft/lb (210Nm) @4750 rpm S14 1982–1990
323i 2316cc 6cyl SOHC 12V Petrol 139-150hp (104-110kW) @4500 rpm 0ft/lb (0Nm) @4000 rpm M20B23 1982–19850
325e 2693cc 6cyl SOHC 12V Petrol 127hp (95kW) @4250 rpm 169ft/lb (230Nm) @3200 rpm M20B27 1982–1990
325i 2494cc 6cyl SOHC 12V Petrol 169hp (125kW) @5800 rpm 163ft/lb (222Nm) @4300 rpm M20B25 1982–1990
325iX 2494cc 6cyl SOHC 12V Petrol 169hp (125kW) @5800 rpm 163ft/lb (222Nm) @4300 rpm M20B25 1982–1990
M3 2302cc 4cyl DOHC 16V Petrol 197hp (147kW) @6750 rpm 176ft/lb (0Nm) @4750 rpm S14 1986–1988
M3 2302cc 4cyl DOHC 16V Petrol 212hp (158kW) @6750 rpm 170ft/lb (0Nm) @4600 rpm S14 1989–1991
M3 Evolution 2302cc 4cyl DOHC 16V Petrol 197hp (147kW) @6750 rpm 176ft/lb (0Nm) @4750 rpm S14 1987–1987
M3 Evolution II 2302cc 4cyl DOHC 16V Petrol 217hp (162kW) @6750 rpm 181ft/lb (0Nm) @4750 rpm S14 1988–1988
M3 Sport Evolution 2467cc 4cyl DOHC 16V Petrol 235hp (175kW) @6750 rpm 177ft/lb (0Nm) @4750 rpm S14 1990–1990
324d 2443cc 6cyl SOHC 12V Diesel 84hp (63kW) @4600 rpm 112ft/lb (152Nm) @2400 rpm M21D24 1985–1993
324td 2443cc 6cyl SOHC 12V Diesel 114hp (85kW) @4800 rpm 162ft/lb (220Nm) @2400 rpm M21D24 1985–1993
Maintenance
Engine Swaps
M50 M52 M30
Main article: Gearbox
Maintenance
A Z3_short_shifter_conversion will help you change gears quicker.
Main article: Differential
Main article: Brakes
For more information on the E30 braking system, check the Brakes.
Maintenance
If needed, E30 brakes can be improved in a number of ways. While some choose to upgrade to rear discs, others prefer to use bigger discs and callipers from newer BMWs, which necessitates an upgrade to a 5-bolt hub.
Main article: Suspension
Steering
Main article: Steering
Body Styles and Fittings
Main article: Bodywork
The E30 was offered in a number of body styles. A 2-door and 4-door Saloon, Cabriolet and Touring
Maintenance
Electrical
Main article: Electrical
The E30 loom is a monstrous labyrinth of wires, all colour-coded, so that you can easily trace exactly which wire does what. All wires inside the cabin are part of a one-piece loom that runs through the bulkhead on the passenger side of UK cars, where they meet the Fuse Box.
Maintenance
Ensuring that all the fuses in your Fuse Box are the correct rating is essential in preventing electrical fires. If you are experiencing blown fuses, DO NOT insert a fuse with a higher rating than that in the diagram.
Tables
{| class="wikitable"
|+'''Table Title'''
|'''First Column Header'''
|'''Second Column Header'''
|'''Third Column Header'''
|We
|Love
|E30s
|Old
|Skool
|Cool
This should look like:
Table Title
First Column Header Second Column Header Third Column Header
We Love E30s
Old Skool Cool
