Megasquirting Your M20
Revision as of 12:38, 7 February 2011 by Gruelius (talk | contribs)
This Page Is a work in Progress by Gruelius. I am not responsible for any incorrect information (feel free to update it).
Ignore the buggered AFR IAT and CLT values, they werent connected :P
Possible Combinations
Motronic 1.3 to Megasquirt
Parts Required
MS2 Extra firmware.
idle driver board.
Wasted Spark
Making the adapter
This is a photo of how i made my adapter (showing coil boards too) Adaptercase.jpg
While that guide is correct, I would and did wire the cps ground to #2, the megamanual hints towards it being a separate ground in future revisions of MS 2dhs0fn.png
Main Relay Triggering
Idle Control Valve
Wasted Spark
Wiring table for wasted spark
Output V2.2 Input V3 Input V3.57 Input
Spark A Right of R25 Top of R26 U1 pin 7
Spark B Right of R28 Top of R29 U1 pin 8
Spark C Right of R26 Top of R27 U1 pin 9
Using the GM V6 Coilpack the internal electronics are to be gutted as we will just be using it for its coils and the coil holder Gmgutted.jpg Gmcoil.jpg
Oxygen Sensor
image by goathumper from http://www.e30tech.com/forum/showthread.php?t=50206&highlight=lc1+install+stock+harnesse O2wiring.jpg
Tacho Output
Apparently the stock level output can run this, if it doesnt work just add a transistor.
Settings
LJET to Megasquirt
Overview & Warning
I have not attempted this so this is just based on available information. This is extremely simple as the ignition is still done by the dizzy so all you need to do is run the injectors
Wiring guide
