Megasquirting Your M20
This Page Is a work in Progress by Gruelius.
Possible Combinations
Motronic 1.3 to Megasquirt
Parts Required
MS2 Extra firmware.
idle driver board.
Wasted Spark
Making the adapter
From [1] run by chris325ix
(While that guide is correct, I would and did wire the cps ground to #2, the megamanual hints towards it being a seperate ground in future revisions of MS)
File:Http://i52.tinypic.com/2dhs0fn.png
Main Relay Triggering
Idle Control Valve
Wasted Spark
Output | V2.2 Input | V3 Input | V3.57 Input |
Spark A | Right of R25 | Top of R26 | U1 pin 7 |
Spark B | Right of R28 | Top of R29 | U1 pin 8 |
Spark C | Right of R26 | Top of R27 | U1 pin 9 |
