ABS Problems
Introduction
The E30 ABS system is adequate for stopping the average driver in the event of an emergency and is rightly so a useful safety system, if it is fitted and not working then the car is also deemed an MOT failure it is important that if it is fitted it works.
Diagnosing The Type Of Problem
If either of the fuses are missing then theres your problem. Another common bodge by bodgers to pass MOT by one of the less observant testers.
Note
ABS System Fault
On the later ABS systems there are two relays, I have always replaced them in pairs (since if one is beyond its best it stands to reason the other of the same vintage will be too) however only one of them contains the voltage protection circuit. They can be opened and repaired too, normally if you open the relay the fault is clear as its usually a blown resistor however the case is difficult to dismantle and fit back together and as they are so cheap I normally replace them as a matter of course.
The later ABS relays are found on top of the ABS pump under a black plastic cover screwed down with one star nut. If you need help identifying the ABS pump you need more help than I can give you!
Fuse/Relay/Wiring
It may still be a relay/fuse problem, but it could also be the ABS pump or ABS ECU or wiring between (i.e. everything bar the sensors and sensor ralated wiring). If you cannot find any problem with wiring then the relays are the cheapest item to replace typically £4 or less from a breaker on Ebayor friendly Zoner including postage. The early ABS system will only accept an early silver relay and the late system only accepts the later two relays.
ABS ECU
Should that not prove to be the problem the next most common problem is a faulty ABS ECU fortunately these are also relatively cheap typically £10-£20, they plug in and out on a fixed loom and are located above the glove box compartment, accessible by removing the plastic sheet which forms the roof of the glovebox from within the glovebox, swapping ECUs is a 5 minute job.
Note
ABS Pump
ABS Sensor Fault
Please Complete
--March109 21:03, 20 July 2008 (UTC)
