Window switch
Revision as of 05:16, 11 September 2009 by Willnz (talk | contribs) (New page: E30s have an annoying problem with the window switches where they will just start working intermittantly, work in one direction only, or stop working altogether. It is an easy fix. First...)
Firstly you need to pry the switch apart, below the tabs holding it together are arrowed. There are the same tabs on the other side. You have to free all 4 or the switch will not open.
img:P1040204.jpg‎
