Building a 2.8
Really, this is pretty much the same as building a 2.7. I first built a 2.8 back in 2001 - 2.8 M52 engines had only been out for around 5-6 years then but there were a few ruined Nikasil short engines about.
The 2.7 525e is now becoming rare - they stopped making them at the end of 1987, most have done big miles and many are just knackered now and need a crank regrind.
The 2.8 M52 was fitted to the E36 328i and E39 528i, both of which are at the scrapyard stage now so an old 2.8 engine with suspected head gasket issues is literally £50 worth of scrap.
The M52 is a later alloy block version of the M50 which itself was only ever a 24v version of the M20. The block dimensions are the same and the 2.8 crank drops straight in. Later ones from the end of 1998 have Double Vanos and these cranks have a TDC trigger wheel screwed to the back as well as bigger counterweights meaning they are hard work to fit - it involved grinding out the block to provide clearance. But do check because some later cranks fit without a problem once the TDC trigger wheel has been removed and binned. But to keep things simple, just use the early single Vanos crank.
The beauty of the 2.8 crank is that it’s 84mm stroke - with standard 325i pistons and 130mm 2 litre, 2.3 litre and 525e M20 ‘short’ rods - allows the pistons to come to the top of the block. No machining of the block face is required although a 5 thou clean up skim is a very good idea.
Now, because the M52 had a timing chain and not a belt, the oil seal ran directly on the crank pulley hub and not the crank. This means you need to make up a spacer to slide onto the crank nose for the oil seal to run on. Fortunately, the M52 (and M50) crank pulley hub is perfect for the job - simply remove the damper (six bolts) and get a machine shop to mill it down to the dimensions shown. This will be the same tightish sliding fit on the crank, and once the crank bolt is tightened fully, it’s not going anywhere. Get the machine shop to mill a nice smooth chamfer on the front of the spacer so the crank oil seal slides over nicely. Use standard 325i crank bearings and rod bolts.
Other pistons?
Compression ratios?
Camshaft
Other stuff
Best exhaust?
The standard BMW factory exhaust gives great power as long as it is a genuine BMW system made by either Boysen or Eberspacher. Some aftermarket systems give more power, many do not. The later cast iron manifold is much maligned - you might get 5 bhp from a tubular manifold but spend the money on a camshaft and a remap first.
How much power?
A good high compression 2.8 with a 270 degree cam, a proper ECU remap and 99 octane fuel will do around 220 bhp.
