Z3 short shifter conversion
.Parts Required.
Description | Part Number | Price (£) | Quantity | Total Price (£) | |
Recondition Parts | Gear selector rod joint | 25 11 7 501 309 | 14.39 | 1 | 14.39 |
Dowel pin | 23 41 1 466 134 | 0.29 | 1 | 0.29 | |
O ring | 25 11 1 221 243 | 0.31 | 2 | 0.62 | |
Spacer ring | 25 11 1 220 199 | 0.12 | 1 | 0.12 | |
Circlip | 07 11 9 932 863 | 0.12 | 1 | 0.12 | |
Short Shift Parts | Gear lever | 25 11 7 527 252 | 36.46 | 1 | 36.46 |
Spacer ring | 24 11 1 220 439 | 0.30 | 2 | 0.60 | |
Circlip | 25 11 7 571 899 | 0.37 | 2 | 0.74 | |
Shift lever bearing | 25 11 1 220 600 | 6.08 | 1 | 6.08 | |
New gasket | Exhaust gasket | 18 30 1 711 969 | 7.96 | 1 | 7.96 |
Total | 67.38 |
