Motronic
Revision as of 14:13, 29 December 2008 by 91.111.127.108 (talk)
Bosch Motronic ECU
Contents [hide] 1 Motronic ML1.X 2 Motronic 4.1 3 Motronic 1.1 & 1.3 4 See also 5 References 6 External links
[edit] Motronic ML1.X Motronic ML1.x was one of the first digital engine-management systems developed by Bosch. The basic idea behind the system was to fully integrate and regulate all major engine system parameters, thereby enabling fuel delivery and spark timing control functions to be controlled by the same unit, in an attempt to achieve optimum efficiency, driveability and power output potential. These early Motronic systems integrated the spark timing element with then-existing Jetronic fuel injection technology.
It was originally developed and first used in the BMW 7-Series[1], before being implemented on several Volvo[2] and Porsche[3] engines throughout the 1980s. It was also used on turbocharged Audi Quattro models during the early 1990s.
[edit] Motronic 4.1 The Motronic 4.1 system was used on Opel/Vauxhall 8-valve engines from 1987-1990[4], and some PSA Peugeot Citroën XU9J-series engines[5].
[edit] Motronic 1.1 & 1.3 The Motronic 1.1 System was used by BMW from 1987. This was then superseded in 1988 by the Motronic 1.3 system[6] that was also used by PSA on some XU9J-series engines (which previously used Motronic 4.1)[5].
[edit] See also Jetronic
[edit] References ^ [1]http://www.bosch.com/content/language2/html/3074_3184.htm ^ [2]http://www.ludd.luth.se/~rotax/motronic/motronic.html ^ [3]http://frwilk.com/944dme/ ^ a b c [4]http://www.opel-scanner.com/files/Opel_MotronicML4.1.pdf ^ a b c [5]http://www.taylor-eng.com/ecu/motronic_intro.html ^ [6]http://www.opel-scanner.com/files/DME_1.1_1.3.pdf ^ [7]http://www.opel-scanner.com/files/DME_1.1_1.3.pdf ^ [8]http://www.opel-scanner.com/files/DME_1.1_1.3.pdf
[edit] External links Bosch.com official website Retrieved from "http://en.wikipedia.org/wiki/Motronic"
