Revision as of 14:41, 21 December 2008 by Keri-wms (talk | contribs)
Basic checks:
What can be improved?
Brake "power"
1 - Larger discs, this in effect increases the leverage that acts on the wheel. Downsides are increased unstrung mass (and rotational mass due to the larger diameter), a slight increase in cost if it's a re-drilled one-piece disc or a larger increase in cost if it's alloy bells and rotors.
Unsprung mass,
Rotational mass
Fade (pad) resistance
Fade (fluid) resistance
Heat reduction
Disc "warping" resistance
E30 upgrade options in stages (increasing in performance and price).
- <<please update me>>
<<Please update me>>
  • Bmw E30M3
  • Bmw E32 750i
Cars with 4pot calipers
  • Aston Martin(various)-DB7
  • Alfa Romeo GTV/166
  • Audi Possibly RS2,S8,RS8
  • BMW E38 728i
  • BMW E31 840i,850i,850csi
  • Ferrari (all newer models)
  • Fiat Coupe
  • Ford Focus RS
  • Ford Sierra RS Cosworth 3dr
  • Jaguar S type R
  • Lancia Delta(integrale)
  • Lancia Phedra
  • Mazda RX-7
  • Mitsibishi 3000GT
  • Nissan 300ZX
  • Nissan 350Z
  • Peugeot 607(possibly)
  • Peugeot 807(possibly)
  • Peugeot 406 Coupe
  • MG MGF
  • Seat Cupra R (Ibiza,Leon)
  • Subaru Impeza STI
  • Toyota Hilux
  • Toyota Celica GT4
  • Toyota Supra
  • TVR ( certain newer models)
