Windscreen Wiper faults
Potential Cure For Stuttering Windscreen Wipers On Intermittent Setting
Originally Written & Photographed by Peter Laing (PeteE30tourer)
One of the most annoying “features” of my cherished E30 is that the wipers barely manage to stutter across the screen when on the intermittent or single wipe settings, even though they work fine on normal or fast modes. Having read several posts on the E30zone forums from others with the same problems, it’s obvious that this is a common problem. I’d read about a possible cure for this in the responses on the forum, so thought I’d give it a go and take a few photos in the process to share it with others. So, here’s what I did.
Step 1 – Remove air-vent panel You need to prize off the plastic air-vent on the passenger side, just below the wind-screen on the scuttle panel with a flat-blade screwdriver. Be sure to use a bit of wood to lever against to save your paint-work or windscreen. There are three clips along the top and bottom edges of this plastic panel as shown below (looking down from the windscreen).
Step 2 – Remove the Wiper Mechanism
First thing you’ll note is that the nut holding on the wiper mechanism isn’t easily accessible, so, get in the car, turn on the ignition and set the wipers wiping, but turn off the ignition as they get to the vertical position, thus stopping them there. The motor/mechanism will now look something like this:
To make life easier later on, mark the position of the mechanism so you can be sure to put it back exactly in the same spot. I used a sharp knife to score a line on the motor mounting bracket parallel to the arm. Remove the single nut from the top of the motor shaft and prize off the mechanism. Move it out of the way. Step 3 – Disconnect the electrics There is an in-line connector mounted on the side of the motor bracket – towards the driver’s side – see photo below.
Step 4 – Removing the motor
Now remove the two larger bolts that hold the bracket to the bulkhead of the car. There is, however, a third bolt holding this bracket on, which can’t be seen nor accessed through the air-vent. To get to this, and to aid removal of the motor, you need to prize away the sound-deadening panel at the very back of the engine bay as shown in the photo below. On mine, this required removing one small bolt (Fixing A in photo) and the two that hold the large, round multi-way connector bracket (Fixings B in photo). You’ll also have to pull away the rubber seal strip along the top edge before pulling away this panel.
You can prize off these four clips to enable removal of this plastic cover, then you’ll have something looking like this:
